15 headlights for sale. Sold
CTLeonard
Last Name: Leonard
Post by CTLeonard » Tue May 20, 2025 1:49 pm
Pair of e and j 440 headlights. Blasted and primed. Good solid buckets. Both reflecters are good. One brass ring has a missing lens clip on the bottom. I believe the arms are early 15, but the adjuster screw is on the left. I don't know the relation to the screws left or on top. 200.00 plus shipping. ctleonard64@gmail.com
Re: 15 headlights for sale
Post by TRDxB2 » Wed May 21, 2025 4:31 am
Very nice set, but not 1915.
The 1915-17 have the focus screw at 12 o'clock (above the socket) while the later ones have it a 9 o'clock relative to the socket.
Note too that the sockets were different as well. The later bases are tapered and fit different fender trons
From the Forum Encyclopedia
1915 HEADLAMPS
(All lamps appeared alike, regardless of make. Early production 1915 lamps varied; made by E & J, they had larger brass rims and lenses (8-5/8 vs 8-1/8”) than later standard style lamps. Lamps were supplied by E & J, Brown, Victor and, perhaps others.
Headlamp lenses were clear glass until 1921.) Steel headlight rims specified in a letter dated June 19, 1915.
6511X with large lens rim. (E & J 456)
6511X with brass lens rim. (standard)
During the latter part of 1914 and perhaps early 1915, headlamps were fork-mounted, on the same forks as used by the carbide lamps. Early in 1915 the lamp with the riveted-in-place post became the standard. All were electric, powered by the magneto with the bulbs wired in series. Brass rims discontinued about June 1915.
1916-1917
Head, Side, and Tail lights were now all painted black but continued the style of 1 915.
Identical to the later 1915 lamps except for the elimination of the brass trimming. Painted all black.
1917-1919
HEADLAMPS 6511BX
In late 1917 a dimmer was added to the light switch on the magneto-powered lamps. The lamps appeared the same as the 1916 style except for the use of bulbs with two contacts (6-8 volt, 16 C.P.) instead of the older single contact type (8-9 volts, 18 C.P.).
Rims for round glass had small claw like tab while H glass has a straight bar.
