Spark Plug Tire Inflator REDUCED TO $25.00 + shipping
aDave
First Name: David
Last Name: Dufault
Post by aDave » Thu Jun 19, 2025 10:31 am
Title is "Spark Plug tire inflator" which is partially correct. Yes, the device fits into a spark plug hole, and yes, it inflates tires....box says from flat to inflated in less than 2 minutes, but the pump can be used wherever compressed air is required: inflating beach toys, air mattresses, spreading pesticides or fertilizer, paint, blowing away dust and chaff, etc. NO - it DOES NOT compress gasoline air....outside, ambient air enters the compression chamber in the device, and is pumped into whatever it is that you want inflated.
MADE in Illinois, USA
aDave
First Name: David
Last Name: Dufault
Re: Spark Plug Tire Inflator $30.00 + shipping
Post by aDave » Mon Jun 23, 2025 12:57 pm
aDave
First Name: David
Last Name: Dufault
Re: Spark Plug Tire Inflator REDUCED TO $25.00 + shipping
Post by aDave » Wed Jul 16, 2025 9:09 pm
Spark Plug Tire inflator reduced to $25.00 plus shipping.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Thu Jul 17, 2025 8:56 am
I bought one of those in the '70's and used it for years until I accidentally melted the hose against an exhaust manifold. It works very well and there's no gasoline in the pump, as Dave mentioned. I know because I did the sniff test.
