I have a nice set of four Hayes wire demountable rims in primer with original hub caps.
Price is $2400.00. I can text or email photos. I give up including photos here I cant get it to work.
You can text me if you like at 631 445 five six nine seven
Manny
Hayes wire rims with hub caps
mklooksup
Topic author - Posts: 93
- First Name: manny
- Last Name: Kourounis
- * REQUIRED* Type and Year of Model Ts owned: 1915 pickup 1915 Delivery van 1925 Fordor at Lillekers 1924 Tudor
- Board Member Since: 2012
Re: Hayes wire rims with hub caps
Manny, do you mean rims on which the tyres are fitted, or the felloes into which the spokes are laced?
mklooksup
- First Name: manny
Allan Ill do my best to post photos here, but they are clincher rims.Manny
Hayes wire wheels with the rolled out outer edge on the felloe that I have had have all been 21" wheels, that take split rims, not clinchers.
You might measure what you have to be clear.
If anyone has a small brake drum off a Hayes wheel. I could use one.
