Looking for parts for the Chicago mark-e auxiliary transmission.
Shift knob
shim gaskets
Internals (what do you have?)
Frame to transmission support
Bryant
WTB Chicago Aux transmission Parts
Bryant
Topic author - Posts: 1219
- First Name: Bryant
- Last Name: Shafer
- First Name: craig
- Last Name: leach
Re: WTB Chicago Aux transmission Parts
Hi Bryant,
I have a friend that has a Chicago Aux. transmission that he would like to sell. It has had some water in it but turns free & all gears work. It is a
little different than the one you just picked up as it doesn't have the large block on the front it just has the square shaft that goes into the T
transmission like a Warford does.
Bryant
- Last Name: Shafer
looking for this main input shaft.
Bryant
- Last Name: Shafer
Found another parts transmission. Has a lot of great better than current parts. Should easily be able to build a solid trans out of the two.
Thanks to Craig Leach!
Not only did he find the transmission he disassembled it to inspect the internals. Disregarded anything unusable to drop shipping weight and Arranged it in a box to ship it at a reasonable price! Great seller!
Great sellers and great buyers make this a great hobby!
Thank you Craig and thank you MTFCA!
Still looking for
Original frame to transmission support
Shift ball or even a picture of an original to copy.
Bryant
Still looking for
Bryant
- First Name: craig
- Last Name: leach
You are most welcome Bryant. If you don't find a original trans support I think you will find Gary London's a close match.
