Stewart Warner 490 speedometers 1926/1927 $150
Topic author - Posts: 63
- First Name: Jeff
- Last Name: Broeckel
- * REQUIRED* Type and Year of Model Ts owned: Roadster pickup 1926
I have two Stewart Warner speedometer heads. Look like NOS.
Tested with a cable and drill motor. Both working.
$150 each or $250 for the pair.
Last edited by 26-Roadster/pu on Tue Aug 05, 2025 8:54 am, edited 4 times in total.
- First Name: Terry
- Last Name: Woods
Re: Stewart Warner 490 speedometers
Dang, Every Model 490 speedo I see is the early model which uses the cable that just jams up into the head and is held in place by a bracket made onto the speedo end of the cable and is held in place on the speedo head with a screw. The later production used a threaded ferrule simular to the Model A speedo heads and is a much more satisfactory and secure way to join the cable to the head. I wish one of yours was the late model. I have two just like yours.
- First Name: Terry
- Last Name: Woods
Well, I answered your post, too soon. I looked on EBAY and there was a late model 490 speedo (Cheap). I bought it with buy it now.ModelTWoods wrote: ↑Fri Aug 01, 2025 12:34 pmDang, Every Model 490 speedo I see is the early model which uses the cable that just jams up into the head and is held in place by a bracket made onto the speedo end of the cable and is held in place on the speedo head with a screw. The later production used a threaded ferrule simular to the Model A speedo heads and is a much more satisfactory and secure way to join the cable to the head. I wish one of yours was the late model. I have two just like yours.
- First Name: Jeff
Re: Stewart Warner 490 speedometers 1926/1927
New price update
- First Name: Jeff
Re: Stewart Warner 490 speedometers 1926/1927 $150
Lower price. I’d like to see someone get to use these. Thanks
- First Name: Jeff
These are nice speedometers. These would be a great replacement or good backup for a 490 speedometer you already have. I’d like to see someone put some miles on these speedometers. Thanks for looking
- First Name: Jeff
Looking for someone to put some miles on these NOS speedometers. Thanks
