WTB Clamp on Metal Stems for Wood Non-Demountable Wheels. Need at least 2 but would take more.
Thanks Tim
WTB Clamp on Metal Inner Tube Stems for Wood Wheels
Tim Hansen
Topic author - Posts: 22
- Last Name: Hansen
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1920 Touring, 1924 Touring, 1926 Touring, 1931 Model A Coupe
- Last Name: Humble
Re: WTB Clamp on Metal Inner Tube Stems for Wood Wheels
Clamp on metal stems came in two diameters. Ford used the thinner 3/8 " stem, and modern metal stem tubes have the thicker 1/2" stem. If you have already have some modern metal stem tubes on your car you will want the thicker clamp on stems so the valve stem covers and washers are the same for all wheels. If you want the 1/2" stem I have one. PM me for details.
Tim Hansen
- Last Name: Hansen
Thanks Jeff. I was able to find and purchase two metal stem 30X3 tubes today. I really appreciate your getting back to me and offer. My problem is solved for now
Thanks again
Tim.
Thanks again
Tim.
