Aftermarket Main bearing tool FS
Tbird
Last Name: Bird
Post by Tbird » Tue Oct 14, 2025 12:56 pm
This is a aftermarket tool for removing and installing the nuts on the third main bearing cap on a 3 dip pan.
$100 plus shipping
Shrshot
First Name: Kent
Last Name: Palazzo
Board Member Since: 2024
Re: Aftermarket Main bearing tool FS
Post by Shrshot » Tue Oct 14, 2025 3:30 pm
Can this tool be used with the engine in the car?
Tbird
Last Name: Bird
Post by Tbird » Tue Oct 14, 2025 6:44 pm
I believe so. Since there is very little room in a three dip pan this allows the user to connect the bolt to the socket and then turn it cranking it out.
