Early Aluminum Trans Cover
pkhammer
First Name: Gregory
Last Name: Hammer
* REQUIRED* Type and Year of Model Ts owned: 1914 Runabout Project
Post by pkhammer » Sat Aug 09, 2025 11:33 am
I have a 1911-1915 Aluminum Transmission Cover with Letter Pedals. Planning to bring to Hershey. $150.00
pkhammer
First Name: Gregory
Last Name: Hammer
Re: Early Aluminum Trans Cover
Post by pkhammer » Sat Aug 16, 2025 5:40 pm
Free pickup at Hershey in October.
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Tue Aug 19, 2025 10:27 am
Wouldn't this be a late aluminum cover considering it has the reinforcing ribs?
pkhammer
First Name: Gregory
Last Name: Hammer
Post by pkhammer » Mon Aug 25, 2025 5:55 pm
I thought aluminum trans covers were only thru early 1916 or so?? It also has the lettered pedals. $125.00 delivered to Hershey.
Last Name: Hatch
Post by Dan Hatch » Mon Aug 25, 2025 6:36 pm
That is a 13/14. 15 had ribbed pedals.
You should show the front to see that the front ears are not broken off.
Post by Wayne Sheldon » Tue Aug 26, 2025 6:37 am
Added FYI. The iron hogsheads began showing up at the factory assembly lines around November of 1915. The assembly line photos of the one millionth engine early December 1915 show both aluminum and iron hogsheads going down the lines.
Smooth and ribbed pedals on US built Ts were pretty consistent with iron and aluminum hogsheads. Canadian Ts continued using ribbed pedals for several more years into the early 1920s on iron and even starter hogsheads.
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Tue Aug 26, 2025 8:27 am
As far as T era you are correct. On the lip straddling the holes are vertical reinforcing webs which were added to the castings. While they are all "early" this casting change occurred around 12 but don't quote me on it. Essentially you had the square hole, then the aluminum, then aluminum with reinforcement, and finally cast iron.
pkhammer
First Name: Gregory
Last Name: Hammer
Post by pkhammer » Tue Aug 26, 2025 3:32 pm
It's packed in the trailer for the trip to Hershey now so it can be found there in north Chocolate C4Y 1-3 along with some other good stuff, but mostly Model A small parts.
-thanks,
