Wanted to Buy - An R G Reeder Aluminum Low Head
J1MGolden
Last Name: Golden
Post by J1MGolden » Fri Sep 12, 2025 8:28 am
Wanted to Buy - An R G Reeder Aluminum Low Head or more information on why no one is selling the low head. Jim Golden
J1MGolden
Last Name: Golden
Re: Wanted to Buy - An R G Reeder Aluminum Low Head
Post by J1MGolden » Wed Sep 24, 2025 3:41 pm
What I really wanted was more information on why the Low Heads have never been reproduced in aluminum.
So far, I have only been SCAMMED by two individuals, one in Texas and one in Pensacola, Florida!
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Post by BRENT in 10-uh-C » Wed Sep 24, 2025 3:55 pm
Jim, I feel your pain also, as I too need a Low (hi-compression) Head for a current project. I hate to butcher a firewall just to run one of the high ones being offered.
Post by speedytinc » Wed Sep 24, 2025 4:11 pm
Maybe this helps.
I am running a low head, milled 1/8" with hi dome pistons. Performs well with 95# compression.
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
Post by BRENT in 10-uh-C » Wed Sep 24, 2025 4:16 pm
Maybe this helps.
I may have to do that ...but I likely will give up 4-5 horsepower.
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Wed Sep 24, 2025 5:18 pm
If you think about it, the difference between a high and low head, from a functional standpoint, is the size of the water jacket/cooling passages. As your engine produces more power, it has more heat to get rid of, so a high head makes more sense from a reliability perspective. That's probably why you don't see as many aftermarket high-compression low heads.
Keep crankin',
Eric
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Wed Sep 24, 2025 6:00 pm
Jim, I live in Texas, and you weren't scammed by ME. You turned down my offer. I am offended you would say I scammed you.
Post by speedytinc » Wed Sep 24, 2025 6:30 pm
Keep crankin',
Eric
I think the point is to have an early engine head that looks original, but performs better. That was my thinking for my 14.
A Prus head would be a better option, but it don't look stock/correct in a brass T.
J1MGolden
Last Name: Golden
Post by J1MGolden » Thu Sep 25, 2025 11:14 am
Terry, you are not the guilty party in Texas, but I was surprised there were more Jason Moores than John Smiths in Texas.
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
Post by BRENT in 10-uh-C » Thu Sep 25, 2025 12:05 pm
Keep crankin',
Eric
Eric. in theory that might seem believable, but it is the Radiator that changes the coolant's temperature, -not the quantity of coolant. If the Radiator cannot dissipate the coolant's heat, then the coolant in a head with more coolant capacity just continues to see the temps match the same as a head with a smaller capacity.
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Post by Bruce Compton » Thu Sep 25, 2025 12:34 pm
Jim: PM sent . Bruce
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Thu Sep 25, 2025 7:43 pm
Keep crankin',
Eric
Ok, Brent, I agree that the radiator is the part that reduces coolant temperature, but the engine also changes the coolant temperature. I also agree that a small increase on the total volume of coolant is irrelevant in this conversation. We all know that when a radiator’s ability to transfer coolant heat to the outside air is compromised, the engine can overheat, i.e. loose fins, crud in the tubes, etc. The other half of the process relies on the block, hoses, and head’s ability to transfer combustion heat out of the iron and into the coolant that is on its way to the radiator. If there are restrictions to coolant flow in the engine, i.e. collapsed hoses, crud in the block, smaller coolant passages, etc., then the engine may overheat, regardless of how well the radiator works. I posit that the high head transfers heat into the coolant better/flows better than a low head. I guess the real question is: why did Henry change to the high head?
Eric
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri Sep 26, 2025 1:07 am
Eric,
IIRC, the lower compression high head was in response to the low quality, lower octane gasoline that was available at the time.
Keith
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Fri Sep 26, 2025 7:17 pm
So are we saying that they couldn't lower the compression using the low head casting? It seems to me that they didn't need to add that much extra material to the head just to lower the compression, simply adding 1/8" to the block side of the casting (adds 22cc/cylinder) would lower the compression enough for bad fuel, more than the difference between low and high heads. Perhaps the lower compression combustion chamber was incidental to the larger water jacket. I personally believe that the larger water jacket improved flow, which in turn, made cylinder temperatures more even from front to back.
Bringing this back to the original question, why aren't there many aftermarket high-compression low heads, I think that the basic "high" design manages heat better and is therefore better suited for running a Model T at higher output levels than originally designed.
J1MGolden
Last Name: Golden
Post by J1MGolden » Sat Sep 27, 2025 9:16 am
Apparently, the cost to build a casting mold is much larger than the market that would be willing to buy one of those heads.
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Sat Sep 27, 2025 1:01 pm
James, you have a good point. Approximately 2 million T’s were delivered with low heads, more than 13 million with high heads. Since these aftermarket heads were sold as “bolt on” upgrades, high heads are a direct replacement for 85% of Model T’s made.
Personally, I think that it’s easier to fit a low head into a high head car than a high head into a low head car (as noted early in this thread), but the 85% “no additional modifications needed” audience is where a maker should obviously focus.
I still wonder if Ford documented their reasoning for increasing the water jacket size with the “new” high head design. Were they addressing a known issue with an improved component, or was it merely easier, faster, cheaper to make?
Keep crankin’,
Eric
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Mon Sep 29, 2025 5:59 pm
I have one that will be going to Hershey next week has never been bolted on light pole 41 or c4I 29-32
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Mon Sep 29, 2025 6:00 pm
I will also have a Giant Power cast iron head that has been magged and milled same place.
Cordes_jeff
First Name: jeff
Last Name: cordes
* REQUIRED* Type and Year of Model Ts owned: 25
Post by Cordes_jeff » Tue Oct 14, 2025 11:46 am
Reeder made low high compression heads with Ford script for a while until Ford threatened a lawsuit. I did some work for Ralph and got a few thru the years. They look good on early cars but do make hand cranking damn tough when the engine is warm.
J1MGolden
Last Name: Golden
Post by J1MGolden » Tue Oct 14, 2025 3:48 pm
Joe, with all the excitement, I missed your note.
My note got me scammed out of $300 for the head and $35 for shipping.
Then $15 more was requested to receive post office notices when mail arrived.
Not a problem, as the Post Office Clerk would not pass the letter envelope to a person with a correct address there!
About that time, I learned that new low head for sale photo was a copy of a photograph of that low head found on this Forum two years ago.
About that time, I got my original letter back with the check in it and the Post Office Note, "No such street address!"
Then I learned you could stop payment on Certified Checks.
With the money back in my account, I got the exact same note that was sent to me the first time with the same words in CAPITALS, etc., but from a different sender!
Others may not be so lucky!
nathanw90
First Name: Nathan
Last Name: Warburton
* REQUIRED* Type and Year of Model Ts owned: 1919 Roadster Pickup
Post by nathanw90 » Tue Oct 14, 2025 6:33 pm
I believe Joe sold his Reeder head quickly! I went looking for it lol
There was another Reeder low in the orange field but had some pitting on the gasket surface all around. $275 wasn't a bad price until I saw the pitting.
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
Post by BRENT in 10-uh-C » Tue Oct 14, 2025 8:00 pm
IMO $275.00 for a pitted head should not be a deal-breaker. An hour with a Tig welder and some alloy rod (-such as Muggy Weld Super Alloy) and those pits can be filled. All heads should be resurfaced prior to installation, -so considering the scarcity of these heads, that should not have been a deal breaker. Aluminum heads on race cars get damaged all of the time. Most good engine shops who deal with race engines can likely add some weld to the pits and resurface it for you.
FWIW, while I would repair it properly on mine or a customer's project, I suspect some of the industrial epoxies such as JB Weld's Extreme Heat high-temp epoxy would work fine in a home shop repair. I use it on blocks with rust pitting around the exhaust manifold ports to fill the pits, and it lives just fine in that environment, so it would do fine on a cylinder head.
Post by RajoRacer » Tue Oct 14, 2025 8:13 pm
Perfect repair job for Belzona !
nathanw90
First Name: Nathan
Post by nathanw90 » Thu Oct 16, 2025 9:16 am
It would've been a spare/resell item for me. So that's why I passed.
Bruce Compton
First Name: Bruce
Last Name: Compton
Post by Bruce Compton » Fri Oct 17, 2025 12:48 am
I have a Reeder low head for sale. Had it at Hershey, but didn't spend much time at my spot as shopping was more important than selling at it was probably my last Hershey. I had it on my '14 roadster for the summer, but a ruptured appendix plus a hernia made cranking a challenge. I put the stock low head back on and am happy with the reduced required cranking effort, but have less power. Pics available on request. I'm asking $300.00 plus shipping, or $350.00 including. Bruce
ModelTMark
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1924 TT, 1923 Touring, 1927 Tudor, 1915 Roadster
Post by ModelTMark » Mon Oct 20, 2025 7:30 pm
in theory, a low high comp head should have more water capacity than orig, but not as much as the high H/C head. I agree with Bret, it's all about the radiator. If you have a new flat tube tad, I'm sure you could cool a an engine with a low H/C head, if one was available.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Mon Oct 20, 2025 8:07 pm
Sorry Jim, after you said that you had one someone jumped on it from Oregon and third party hauled it home for him.
J1MGolden
Last Name: Golden
Post by J1MGolden » Tue Oct 21, 2025 4:38 pm
Joe, I have bought a few things from you every year at Hershey with good results, but I never found you this year!
You are on my Good Model T Guy List anyway.
