lug wrench for wire wheels
Wingnut
First Name: William
Last Name: Reep
* REQUIRED* Type and Year of Model Ts owned: 1924 roadster, 1926touring, 1926 Coupe
Post by Wingnut » Mon Oct 20, 2025 9:13 am
G'Day everyone, I'm trying to chase down what may be the Unicorn of T tools. The late lug wrench, which has several part numbers, one of which is 5Z-161, then there is T-2891, also 2839. These are T handled and have a socket at the end. A friend of mine asked around at Hershey but no one ever heard of such a thing. Any help would be outstanding. Wingnut
Adam
First Name: Adam
Last Name: Doleshal
Re: lug wrench for wire wheels
Post by Adam » Mon Oct 20, 2025 11:20 am
Good news; it’s not a “unicorn”. For around $40 you should be able to buy one somewhere / from someone online TODAY. Sometimes they are in $1 to $5 tool piles with generic tools at swap meets. You will have to look for them since 99% of the time the vendor that has one has no idea what it is.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Mon Oct 20, 2025 12:44 pm
T-2839. Ford wrench. Sorry not for sale, just acquired but picture should help on your search .. handle measures 10 in. Long, shaft measures 8 in.
Post by TXGOAT2 » Mon Oct 20, 2025 4:00 pm
You could make a very similar tool by cutting down a Wal Mart 4 way lug wrench. W-M offers an inexpensive 4-way that has a socket that fits the T lug nuts well. I carry one in my T along with a lightweight W-M scissor jack. From the socket ends to the center of the 4-way measures 8", like the original, and you could make the handle portion 10" like the original, or longer if you wished.
Moxie26
Post by Moxie26 » Mon Oct 20, 2025 4:54 pm
I thought we were discussing original FORD tools, not ones that we could make ourselves.
Post by TXGOAT2 » Mon Oct 20, 2025 5:06 pm
Whatever. Lug wrench, discussion, wattever.
Post by Allan » Mon Oct 20, 2025 6:17 pm
Look out Pat. You are being too helpful.
Allan from down under
ModelTMark
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1924 TT, 1923 Touring, 1927 Tudor, 1915 Roadster
Post by ModelTMark » Mon Oct 20, 2025 6:33 pm
Thanks for posting the pictures of the tool, I've have one for years but never knew it was the lug wrench for Model T wire wheels. I have two T's with Ford Wire wheels, so I'm sure I can put it to good use.
Post by RajoRacer » Mon Oct 20, 2025 6:36 pm
I sent you a reply regarding the lug nuts, Mark .
Wingnut
First Name: William
Last Name: Reep
Post by Wingnut » Mon Oct 20, 2025 6:56 pm
Thanks for all the input, this forum is a Godsend for advice and information . Steve, did you send an email, don't know if I saw it. Wingnut
ModelTMark
Last Name: Williams
Post by ModelTMark » Mon Oct 20, 2025 7:56 pm
I responded to your email earlier, on the nuts. My wife and I had company for a few days that distracted me. Sorry for the slow response.
rondupree
First Name: Ronald
Last Name: Dupree
Post by rondupree » Wed Oct 22, 2025 9:47 am
Have you found your wrench? If you haven't I will look through my pile.
Ron Dupree
Moxie26
Post by Moxie26 » Wed Oct 22, 2025 12:27 pm
Ron, thanks very much for offering & helping " Wingnut " on obtaining a original issue Ford wire wheel lug wrench... Per chance, if you are at a loss, I'm sure there are others that could be of assistance to "Wingnut " seeking a original wrench.
Wingnut
First Name: William
Last Name: Reep
Post by Wingnut » Wed Oct 22, 2025 10:04 pm
Ron, sent you an email, Wingnut
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Fri Oct 24, 2025 5:52 pm
I just bought one.
The Part Number looks like T-2689 but it does not curl around the shaft.
There are two slightly smaller versions with similar numbers.
Bruce McCalley lists them in his big black book with Model T 1926 Tools.
Moxie26
Post by Moxie26 » Sun Oct 26, 2025 1:05 pm
Looking for wire wheel, lug nuts?... Well chaffins has run a supply of very NOS. Looking shaped plated lug nuts, you can see the extra quality put into this when you compare it against what's on the market
Brand X crap
Brand X crap
Chaffins quality
Chaffins quality
sweet23
First Name: Darryl
Last Name: Bobzin
Post by sweet23 » Tue Nov 04, 2025 9:58 pm
I sent you an e-mail. Darryl
Post by Allan » Wed Nov 05, 2025 6:55 am
There are modern wheel nuts which are a close approximation to the original T wire wheel nuts, but they will be chromed. Chaffin's look even better shaped, but are they chrome too? They are certainly 100% machined, like the flanged wheel nuts Lang's provide for loose lug demountables. All are perfect clones of the next.
However, both styles of original nuts were stamped. The process means all of them are close approximations of the next. Each has their own individual markings/variations, from slightly different faces, offset drilling of the holes, somewhat distorted crowns etc. Finding a good set not rust pitted or socket damaged, suitable for Nickel plating, is a real challenge. We have Lang's and Chaffin's to thank for providing a really nice alternative.
