WTB antique air cleaner
LittleTimmy52
Topic author - Posts: 137
- First Name: Lucas
- Last Name: Milatti
- * REQUIRED* Type and Year of Model Ts owned: 1917 Model T Touring
- Board Member Since: 2025
I have a foam filter, aside from not looking right, most of the antique air cleaners ive seen go up and towards the exhaust. If anyone is selling one per chance I'd love to buy it.
Edit: I am open for any old cyclone type filters, even off an old tractor or something, I say that cause some of the cleaners I was offered get pricy, don't doesn't have to be the one I listed in the images, it just had to function the same way, I can adapt it to fit.
LittleTimmy52
- First Name: Lucas
Re: WTB antique air cleaner
2 examples of kinda what I'm looking for
LittleTimmy52
- First Name: Lucas
I am still interested in one if anybody has one for sale.
LittleTimmy52
- First Name: Lucas
I got scammed cause I am an idiot, once I get my money back I am going to be back on the hunt, I will also be reaching out back to those who contacted me but I am doing my homework on those who contacted me this time. I am still interested in getting one but later on, so if anyone has one sitting on a shelf somewhere Ill be open for an offer just after I get my money back cause I cant afford it otherwise. Thank you.
Linus Tremaine
- First Name: linus
- Last Name: tremaine
- * REQUIRED* Type and Year of Model Ts owned: I do not have a model T. But I like them. I Have a 1930 Lincoln.
I have one of these spare but it is the fancy kind from a model L lincoln that has the nickel plated trim strip around the base. That makes them more spendy than the one you have in your photos. I would be happy to sell it to you as my car has the trim piece and I dont need the spare, but they are generally worth about 250 dollars.
Let me know if you want me to send a photo.
L
L
Linus Tremaine
- First Name: linus
Here is a pic of one on a car from the internet, you can see the basic similarity and the ring I was talking about. These have a cas aluminum base that originally threads onto the air intake elbow. The threads are male.
L
L
ModelTWoods
- First Name: Terry
- Last Name: Woods
A Dodge Brothers filter from the 1920's (not sure of year) looks similar to the one in the picture that you posted, however, it doesn't have a curved elbow, so it would fit horizontally; not vertically, and wouldn't fit. It fits the intake of a Stromberg OE-1 carburetor, perfectly. I had one but sold it when I sold my Model B intake and exhaust and my OE-1 to a speedster builder.
LittleTimmy52
- First Name: Lucas
Hmm, I never thought an air cleaner would be so much, maybe it might be worth finding a rusty old one off a tractor and making it fit. That model l cleaner would be perfect but I can't afford it and I don't want to offend you with what I thought I would have had to pay.
Unless you intend on "off-roading" on a dirt track or you live on a dusty dirt road, why bother ?
There's always debris in the air around traffic, as any motorcycle rider can tell you. A Model T moving at any significant speed will kick up debris on most any paved surface, even away from traffic. In wet weather, road spray will contain grit. Filtered air reduces ring, piston, and cylinder wear significantly and also reduces combustion chamber deposits, particularly on spark plugs and exhaust valves.
Reproduction Air Maze filters are sold for Model A Fords. They won't fit a T, but could be adapted to fit. The Air Maze filter has a wire screen element that can easily be cleaned and re-oiled. Pleated paper filter elements are available in a huge array of sizes and shapes for thousands of applications. Some of these are of s suitable size and shape for use on a T, if you don't mind making your own canister or box and plumbing. You could also make a period-looking cover for one of the vendor foam filters from a bean can or tomato sauce can.
Do you run an air filter, Pat ?
Indeed I do. Ive seen what running without one can do to an engine.
LittleTimmy52
- First Name: Lucas
Yeah if I can't find one in my price range I was planning on adapting some higher flow filter or making something. I just figure I try to find an antique air cleaner cause they look cool. But cost is my deciding factor here.TXGOAT2 wrote: ↑Fri Nov 07, 2025 1:11 pmReproduction Air Maze filters are sold for Model A Fords. They won't fit a T, but could be adapted to fit. The Air Maze filter has a wire screen element that can easily be cleaned and re-oiled. Pleated paper filter elements are available in a huge array of sizes and shapes for thousands of applications. Some of these are of s suitable size and shape for use on a T, if you don't mind making your own canister or box and plumbing. You could also make a period-looking cover for one of the vendor foam filters from a bean can or tomato sauce can.
ModelTWoods
- First Name: Terry
- Last Name: Woods
There's one for a 31 Chevy on EBAY right now, but ir is pricey, over $100-150 .
Daisy Mae
- First Name: Kurt
- Last Name: Andersson
- Board Member Since: 2024
I have an air maze on my Model A.
Living on the Emerald Coast, with fine white sand, anytime the wind is blowing you can see the sand blowing in the air.
Don't need open throats here!!
Haven't yet fabricated something for the T...
Craig Leach
- First Name: craig
- Last Name: leach
Hi Lucas,
I have one of these I think it came off a Chevrolet with a Carter carb. Craig.
- First Name: Henry
- Last Name: Lee
The good ole "Cyclone Filter"...., Have used plenty over the years Craig! I like the 1928 Chevy ones the best!
