WTB headlight lenses for 1913
TillieTheTouring
Topic author - Posts: 29
- First Name: William
- Last Name: Naquin
- * REQUIRED* Type and Year of Model Ts owned: 1920 Touring. 1923 Touring, 1924 Pickup
A fella here is looking for a pair of headlight lenses for a 1913. Grateful to any who can supply.
- Last Name: Tannehill
- Board Member Since: 2002
Re: WTB headlight lenses for 1913
Go to your local glass company & have them cut to size. They should be a clear lens anyway. In my neck of the woods about $30 for a pair.
MikeG
- First Name: Mike
- Last Name: Ghormley
I'm running 12v LEDs in my '14 in lieu of the original HOT carbide flame so I just used plexiglass from Amazon. You can get two 9" round 1/8" thick acrylic disks for less than $10. You will need to grind them slightly smaller in diameter on a grinding wheel to get them to fit, but the advantage is they are cheap, lightweight, and won't break your heart if you happen to drop one of them.
- Attachments
- HeadlampGlass.jpg (16.77 KiB) Viewed 348 times
You need to be more specific. What brand?
