Original Winfield carburetor adaptor. Cast aluminum, with S-63 numbers cast into it. Has a threaded hole for fuel primer or brass plug. Measures 1-5/8 between center of holes on square mounting side. 2-11/16 between center of holes on manifold mounting side. 1-7/16 x 1-1/2 diameter taper in bore. 1-1/2 opening on square side. 75.00 includes shipping.
FS Winfield Carburetor Adapter
ThreePedalTapDancer
Topic author - Posts: 1714
- First Name: Ed
- Last Name: Martin
ewdysar
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
Re: FS Winfield Carburetor Adapter
"S63-Drop adapter flange-SB Winfield to 1 1/4" S.A.E. Manifold where Manifold is tapped."
Winfield Carburetor Company (April, 1930) p.7 "General Information Regarding the New Model "S" Winfield Carburetor."
