FS 23” TT Rear Wheels and Rims SOLD
Tparts
First Name: Don
Last Name: Lang
* REQUIRED* Type and Year of Model Ts owned: Multiple years
Post by Tparts » Mon Dec 15, 2025 8:29 pm
Barn Find pair of 23” Ton Truck Wheels and Rims. SOLD plus shipping or free delivery to Luray Va Swap Meet in May.
Lang’s 1-800-872-7871
James
Last Name: McFall
* REQUIRED* Type and Year of Model Ts owned: 1925-ish T
Re: FS 23” TT Rear Wheels and Rims $500.00
Post by James » Tue Dec 16, 2025 10:35 am
Well, I guess I've saved up enough money to start buying stuff again! These will fit the Ruckstell axles?
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Tue Dec 16, 2025 11:37 am
The Ruckstell axle assemblies use the stock axles for their setup.
BUT... The car axles (and its rear wheels) and the TT truck axles (and its rear wheels) are different.
Wheel hubs, hub caps, spokes, brakes, felloes, rims, tires, etc are different between the TT truck and the cars.
And the TT trucks used different wheels front and back making the rear truck wheels hard to find.
Your profile says "1923 T truck conversion"
Check to make sure what wheels you need on your conversion truck, sometimes they are not even Ford parts.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Dec 16, 2025 12:05 pm
Pretty sure TT front wheels are same as passenger car. Could be mistaken but............what is different?
Post by RajoRacer » Tue Dec 16, 2025 12:09 pm
Nothing - same front wheels.
James
Last Name: McFall
Post by James » Tue Dec 16, 2025 12:15 pm
The problem I have is the thing is more a collection of parts than anything else. Which makes getting parts annoying to say the least. I do have a pair of hubs that fit, and a few different front wheels I've collected. From what I can tell, it is a ton truck rear end because of the large axles.
Last Name: Gregush
Post by Mark Gregush » Tue Dec 16, 2025 1:26 pm
To be 100% post a photo of the rearend in question.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Tue Dec 16, 2025 3:20 pm
In spite of my attempt to be as clear and accurate as possible, what I wrote could be misleading.
What I wrote
"And the TT trucks used different wheels front and back making the rear truck wheels hard to find."
Should read
"And the TT trucks used different wheels front and back on the same truck, making the rear truck wheels hard to find.
The front wheels on a TT truck are the same as the front wheels on the cars"
Pictures of the rear axle can help a lot identifying parts.
Sorry if I caused undue confusion
Mike
James
Last Name: McFall
Post by James » Tue Dec 16, 2025 4:56 pm
Should read
Mike
No problem. All these different sizes confuse me anyway. I talked to them about the wheels. Waiting to hear back on the shipping cost.
slang250
Last Name: Lang
* REQUIRED* Type and Year of Model Ts owned: 1912 touring, 1926 speedster, 1926 TT
Post by slang250 » Tue Dec 16, 2025 6:35 pm
Wheels have been sold to James,
Thank You
