Fender Mounting Brackets
Topic author - Posts: 3023
- Last Name: House
Is there any interest/need for ‘18-‘25 front and rear fender mounting brackets ? I’m considering scrapping many unrestorable fenders but would like to remove these brackets for future use. Altho slightly pitted, they’re all solid. Do new fenders come with brackets ? In the picture I’ve heated the eyelet nut for removal.
Re: Fender Mounting Brackets
1909-1916 error fender brackets are/have been reproduced & early fenders have the correct brackets riveted into place using the correct size and shaped rivets (Rootlieb). Your fender brackets are a desirable part since the 18-25 repro fenders don't come with them. Good eye bolts are desirable as wellGeorge House wrote: ↑Sat Feb 28, 2026 11:06 amIs there any interest/need for ‘18-‘25 front and rear fender mounting brackets ? I’m considering scrapping many unrestorable fenders but would like to remove these brackets for future use. Altho slightly pitted, they’re all solid. Do new fenders come with brackets ? In the picture I’ve heated the eyelet nut for removal.
- Last Name: House
Good news.. thanks Frank… I’ll start collecting them
Just need grind off the rivet heads on top of the fender.
