FS cowl gas tank
Karl Von Neumann
Topic author - Posts: 895
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
FS cowl gas tank
Cowl gas tank does not leak solder has been touched up round the outlet. Over flow tube is broken off at the outlet Decent looking usable tank $200 plus the ride or local pick up pleasant prairie wisconsin can sell you the straps for an additional 50$
Karl Von Neumann
- First Name: Karl
Karl Von Neumann
- First Name: Karl
schwabd1
- Last Name: Schwab
Re: FS cowl gas tank
Is this an open car or closed car tank?
Karl Von Neumann
- First Name: Karl
26 27 is all the same goes under the cowl
Isn't the four door closed car tank on the 26-27 under the seat?
Karl Von Neumann
- First Name: Karl
Yes! I was just thinking about that the 4 door is under the seat thebrest are cowl mount
schwabd1
- Last Name: Schwab
I always thought they were the same, but doing a little research led me to information the open cars were a little shorter and the radius was different. A note on the VowellArt illustration also notes this and advises they cannot be interchanged.
Mike Silbert
- First Name: Mike
- Last Name: Silbert
The 26-27 Cowl tank fits the Roadster, Touring, Coupe, and 2dr sedan.
The TT Truck, Car Chassis, and Fordor kept the Oval Tank of previous years.
The Fordor sedan body was just a modified cowl with general improvements body that was introduced in 1923.
These were still made by outside suppliers and have lots of variances and improvements over the years.
The differences between the years and makers could fill pages of print.
That said, the "1926" and "1927" cowl tanks are different in the outlet fitting casting, overflow tube, and where the overflow lock screw is located.
The screw was moved to make assembly easier coming down the production line.
It is a subtle change and not usually noticed, the whole tank and overflow tube assembly interchange.
Model T parts are a rolling evolution of improvements through the years.
For every "rule" there is at least one exception.
Mike
Mike
I don't think any two of them were actually 100% identical, contrary to the legend.
