Model T Boat Motor
jawa
First Name: Adam
Last Name: Spatto
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring, 1927 Tudor, 1913 Speedster
Model T Boat Motor
Post by jawa » Sun Jan 18, 2026 1:58 pm
Turns over freely. Have not even tried to start. I picked up with plans to clean it up and get it running but I don't have the time. Cool piece. I can send more pictures if you contact me. $850 picked up in central New York.
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Re: Model T Boat Motor
Post by frontyboy » Mon Jan 19, 2026 12:51 pm
Just wondering if this is not a ground power unit, pump motor or farm unit to run farm machinery. I have seen several model t engines in marine applications, and none had the framework or radiator attached, and used the planetary transmission for propulsion.
Model t marine engines I have seen had direct sea water cooling. To me this unit appears to be a factory built stationary power unit. Just a suggestion I've been wrong before. If it was not 3000 miles from me on the right coast I could be interested.
just sayin,
frontyboy
Last Name: Hatch
Post by Dan Hatch » Mon Jan 19, 2026 3:00 pm
I would like to see the oil pan. Not looking to buy, just curious how they did it? Thanks Dan
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Mon Jan 19, 2026 7:12 pm
Besides the oil pan, I am curious about what they did to oil the bearings and the rest of the engine.
Way to far for me to go visit and I definitely do not need even more projects.
Mike
jawa
First Name: Adam
Last Name: Spatto
Post by jawa » Mon Jan 19, 2026 9:23 pm
It looks like a casted oil pan and my guess is there is some sort of oil pump that runs off the cam. If you look closely there is a little oil sight glass.
