Re: For Sale: Accessories & More
Post by RajoRacer » Fri Feb 27, 2026 7:34 pm
Found a nice original set of early firewall brackets - I'd take $75 for the pair & split the shipping. Pikes Peak large drum brakes still available - price out repro Rocky Mtn. & see what the better deal is ! $500 + the ride now. Drop me a note through the Forum, please.
David Greenlees
First Name: David
Last Name: Greenlees
* REQUIRED* Type and Year of Model Ts owned: 1915 Model T racing car, 1924 Model T Depot Hack with original York #803 body.
Re: Re: For Sale: Accessories & More
Post by David Greenlees » Sat Feb 28, 2026 11:38 am
Steve, Are these brakes energizing, and will they work in reverse as the original Rock Mountain brakes do.
Will they fit on a small drum rear axle? Have you found or can find the original pedal that you mentioned earlier? Thanks
Post by RajoRacer » Sat Feb 28, 2026 12:38 pm
Yes, they work forward & reverse & no, they're for a large drum rear end. No pedal - it went with the other set last year. I have a Bennett pedal for both narrow (like new) & a wide - '26 - '27 with a little wear.
