Located in No. Illinois, I am hunting for a couple of 30x3 used but drivable tires. White, black, gray it doesn't matter.
Does anyone have a couple collecting dust?
Thanks,
Jim in Oswego
Wanted: 30x3 Used Tires
Fozz71
Topic author - Posts: 283
- Last Name: Chochole
- Board Member Since: 2003
Adam
- First Name: Adam
- Last Name: Doleshal
Re: Wanted: 30x3 Used Tires
I should have a few. Choices from $125 each on up. Decent clincher tires are all but impossible to find. There is generally always some defect that seriously affects their usability that should be visible if carefully inspected, so I advise never to buy a clincher tire unless you can see it in person. Located in Wisconsin between Madison & Milwaukee. Email thru the forum if interested.
