WTB lower panel TT closed cab rear and roof rib drawings
Post by Mark Gregush » Mon Mar 23, 2026 9:47 pm
WTB the back lower panel for the closed cab. Want to see if there is one available before I try to make one myself. Also, are there any drawings with dimensions for the ribs and side tack rails for the top? For the tack rails, guess I could use that modern material but don't know if the ribs are straight or cut with a curve.
Mark
