its how the camera is held
Topic author - Posts: 353
- Last Name: Grzegorowicz
- * REQUIRED* Type and Year of Model Ts owned: 1921 T pickup
I've tried over and over--this is what i found to be my problem in posting pictures, some would come right up while others taken with the same camera would not--i was thinking if the picture is taken with the same camera how could this be,---DAH----when taking a bunch of pictures some horizontal, things fill the screen fine while others the camera needs to be held in the vertical position, that-'s where the size changes, move the object in a way so the camera is held in the horizontal position,or at times in the delete column there is a place to rotate your photograph to make it the proper size, --geeese i'm getting to be almost 1/2 as smart as this rig--i think. you need to be plugged into just pictures when rotating the photo,
Re: its how the camera is held
I do not post pictures directly from a camera to the forum. I download them to my pictures on my desk top computer and then rotate them the way I want them and save. That way I can get the proper orientation when I post on the forum.
