Icons
Can’t log in? Having a problem with the Forums? Have a question about how something works? Get support here.
FundyTides
First Name: David
Last Name: Wilson
* REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Icons
Post by FundyTides » Wed Apr 24, 2019 9:48 am
Icons don't change color to indicate topics that I have already read. All postings remain red. I am signed in What am I doing wrong?
AdminJeff
Last Name: Stevenson
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Re: Icons
Post by AdminJeff » Thu Apr 25, 2019 7:44 am
They do if you click refresh or click on the link at the top of the page to get back to the topic list. You are probably hitting the back arrow on your browser. That takes you back one screen but does NOT refresh the page. 2 fixes
Hit refresh after going back or use the next topic button and then go back to the index. This is a browser issue on your end.
Here’s what they look look like when working. The middle one has been read.
Assistant WebSite Admin
www.modeltregulators.com
www.modeltstarters.com
FundyTides
First Name: David
Last Name: Wilson
Re: Icons
Post by FundyTides » Thu Apr 25, 2019 10:15 am
Jeff, Thanks for the quick reply. You are right, if I click on "reload this page" the icons that I have read change color. A bit cumbersum but I assume if I just do this before I leave the forum each time the icons will get updated or do I have to do it each time I leave a particular topic?
AdminJeff
Re: Icons
Post by AdminJeff » Fri Apr 26, 2019 7:39 am
When the list is updated is up to you. The next time you visit the forum the list would be updated. It’s the Same for new topics. If you stare at the page of topics for a day, you’d never see new topics. You have to refresh your browser to see new anything.
Jeff
fschrope
First Name: Fred
Last Name: Schrope
* REQUIRED* Type and Year of Model Ts owned: 1923, 1926, 1927 TT's, 1918 cutoff touring, 1922 Coupe - original
Re: Icons
Post by fschrope » Sun Apr 28, 2019 8:59 pm
I've never understood why folks don't refresh the main page and then "right click" the topics that interest them and "open in a new tab". Do the whole page and then read the tabs and close them as you're done reading them. Simple...........at least to me and it applies to all the different browsers I've used. It will even work pretty well with "dialup".
ChrisB
First Name: Chris
Last Name: Brancaccio
Re: Icons
Post by ChrisB » Sun May 12, 2019 1:48 pm
Also if you use the link at the bottom of the page
Return to “Forum Support Questions”
the icons should display properly.
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
