post a pic?
Barteldes
Topic author - Posts: 100
- First Name: Bill
- Last Name: Barteldes
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coup
post a pic?
How do i put a picture in comments. i tried to copy and paste but that didnt work.
BIll B
No matter how you shake and dance the last few drops go down your pants.
RVA23T
- Last Name: C
Re: post a pic?
What are you using to do you posting?
PC?
Mac?
Smart Phone?
or a fruit (iphone)?
AND how familiar are you with editing a photo on your preferred posting device? most times all it takes is a crop or rotation to make photos post-able here.
Barteldes
- First Name: Bill
Re: post a pic?
i have a pc took the lpic with my iphone and emailed it to my pc, copied it to desktop and tried to copy paste into the forum comment.
BIll B
RVA23T
- Last Name: C
Re: post a pic?
Instead of cut & paste, you will need to use the attachments option:
After the attachment is uploaded and the GREEN CHECKMARK is present:
And to have the picture placed through out the body of your text, use "PLACE INLINE" after the curser is behind the text you are emphasizing.
Like this 1925 RPU:
RVA23T
- Last Name: C
Re: post a pic?
Same Files, with out "PLACE INLINE" use. They will post in the same, top down sequence, they are listed in the attachment list.
RVA23T
- Last Name: C
Re: post a pic?
Want to post just a picture, without dealing with the minimum text/letter requirement?
Simply upload the files and use the "PLACE INLINE" button I added a "FILE COMMENT" that will appear under the photo:
RVA23T
- Last Name: C
Re: post a pic?
Your file will not attach if you see the yellow triangle VS the green check:
You will need to edit the picture and resave it in order to upload to the forum.
Sometimes a simple crop down to the original file/photo will fix it, using the rotate might fix it, making color, tint, tone type of edit will help, and there are options to resize smaller but that is dependent on your editing software.
Mark Nunn
- Last Name: Nunn
Re: post a pic?
Photo test
RVA23T
- Last Name: C
Re: post a pic?
Looks like an Error, it removed one of your pistons!!!
