Need Help-How to Post Photos
Can’t log in? Having a problem with the Forums? Have a question about how something works? Get support here.
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Thu Sep 24, 2020 3:14 pm
I want to post photos. Can someone guide me thru the procedure? I also need to know how to resize photos.
Last Name: Strange
Re: Need Help-How to Post Photos
Post by CudaMan » Thu Sep 24, 2020 3:26 pm
Usually, if you can get your photos onto the same PC as you are using to look at the forum, you can just click on the photo and drag it into the text box, that's all I did with this picture:
Last Name: Hjortnaes
Post by DHort » Thu Sep 24, 2020 3:34 pm
Steve and I replied on your Sept 20 post. Did that work for you or are you still having issues? Size should not matter. Let us know. Good luck.
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Post by Altair » Fri Sep 25, 2020 12:01 am
There is more than one way to post pictures. I use a small camera and take pictures in email mode for best results ie the smallest number of bits and bites. When you click on post a reply at the bottom of the page there is "ATTACHMENTS" click on that, then "ADD FILES" your picture library will be displayed click on the picture then click on "OPEN" it will return to your post then click on "PLACE IN LINE". For this procedure the photo would have to be previously down loaded in to your computer either in "PHOTOS" or on the thumb drive usually "E" file. All filed photos have an ident number if you know the file number you can enter that number in the space provided click on it to display the picture then click on the picture then open and you are there. When you have done it a few times it takes about about 5-10 seconds to post a photo.
Post by Steve Jelf » Fri Sep 25, 2020 12:39 am
As Mark says, there's more than one way to skin that cat. There's the method David explained and I described in your previous post. There's also drag & drop as Mark described, like this:
I just dragged it into the composition box and clicked Place inline below the box.
Most of the photos I post are full size and I almost never have to shrink them.
If our instructions aren't clear enough to follow, have a kid teach you how.
:D
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Sat Sep 26, 2020 8:34 pm
How do you resize photos? Is there a program to download on the computer? David said size should not matter. I have noticed references to resizing so I am confused.
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Wed Sep 30, 2020 1:48 pm
Need answer to my 9-26 questions>
Post by Mark Gregush » Fri Oct 02, 2020 12:26 pm
What procedure are you doing when you try and post? What is your results? Are you getting the yellow warning or? Are you using Windows 10 or Apple? This test picture is 4000 x 3000 and 2.6 MB's. If you hold your mouse over the pictures you are trying to post what are there sizes?
Post by Steve Jelf » Wed Mar 29, 2023 12:22 am
When I started seeing the "landscape" and "portrait" designations in recent years I was mystified, but eventually figured out they mean horizontal and vertical. (When did we adopt the British term roundabout for traffic circles? And start saying "graduate high school" and "year anniversary"?)
Anyway, when I have a vertical photo show up turned horizontal I go back to the original and rotate it 90º left, then back 90º right (or vice versa) and it posts correctly. I have no idea why this works, but it does.
WildwoodCastle
Last Name: Hill
* REQUIRED* Type and Year of Model Ts owned: 1912 Commercial Roadster/Truck - 1913 Touring
Post by WildwoodCastle » Mon Jul 28, 2025 5:06 pm
I posted a photo.. I posted a photo... Yee-Haw..!
TillieTheTouring
First Name: William
Last Name: Naquin
* REQUIRED* Type and Year of Model Ts owned: 1920 Touring. 1923 Touring, 1924 Pickup
Post by TillieTheTouring » Mon Nov 03, 2025 7:57 pm
[image][/image]
TillieTheTouring
First Name: William
Last Name: Naquin
Post by TillieTheTouring » Mon Nov 03, 2025 8:09 pm
I am baffled. I really need to post a Pic of a broken top bow, but I simply cannot upload a picture to the forum. I feel like this should be easier.
