How to get to older forums?
Topic author - Posts: 667
- First Name: William
- Last Name: May
I am trying to find the forums for 2010, specifically the ones dealing with a home-built crank type coil tester and adjuster, I think from the November 2010 forums. How to I get to them?
Re: How to get to older forums?
google "hand crank coil tester" You can access 2017 and 2018 thru the main menu on the forums list. Other wise you need to do the suggested search and look for dates in what you find.
I found this doing so;
http://www.mtfca.com/discus/messages/80 ... -93057.pdf
- Last Name: May
Thanks very much! That is exactly what I was looking for!
BIll
BIll
