Got kicked off again.
Can’t log in? Having a problem with the Forums? Have a question about how something works? Get support here.
StanHowe
First Name: Stan
Last Name: Howe
Post by StanHowe » Thu Feb 07, 2019 2:46 pm
I've gone through this registration/can't log in/etc., etc thing about half a dozen time since the new forum format was activated.
Is anyone else having the problem?
I'll do the whole "new password" thing again and see if it works.
Tom Hicks
First Name: Thomas
Last Name: Hicks
* REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
Re: Got kicked off again.
Post by Tom Hicks » Thu Feb 07, 2019 2:59 pm
Well, yeah, since you are on, I guess it finally worked. I had a devil of a time getting on yesterday, but whatever the problem was has apparently been fixed.
I have a lot of problems with any "technology", and I think the forum change has been relatively smooth.
Please have patience, there are good men working on it...
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Thu Feb 07, 2019 3:11 pm
I have had very few problems using this login pathway
https://www.modeltfordclubofamerica.com/phpBB3/
Use for your bookmark as well😊😊
Tony Bowker
La Mesa, California
George Andreasen
Last Name: Andreasen
* REQUIRED* Type and Year of Model Ts owned: 0...building from parts
Post by George Andreasen » Thu Feb 07, 2019 3:24 pm
Tony's got the right idea. That's how I finally solved all of my login problems.......just made it a bookmark. Thanks to our mods for that tip!
DanDy
Last Name: Doughty
* REQUIRED* Type and Year of Model Ts owned: 17 roster, 17 touring, 22 coupe, 22 touring, 22 roadster pu, 24 TT cab
Post by DanDy » Thu Feb 07, 2019 4:08 pm
I was blocked using my Mac with Safari. Now use the Mac with Google Chrome and it works fine. Puzzling!
Marv K
First Name: Marv
Last Name: Konrad
* REQUIRED* Type and Year of Model Ts owned: '26 TT Steel Cab ("ToyBox Twoo"), '25 Coupe ("Cranky")
Board Member Since: 2010
Post by Marv K » Thu Feb 07, 2019 5:19 pm
-Stan-
Tony identified the link, and George ID'd the 'bookmark' of it. That is the route I've used, and it has worked every time. FYI, you might want to check-mark the "Remember Me" box if you're wanting to go back & forth between 'classifieds and/or discussion'.... FWIW - Not a bad idea either to log out when you're shutting things down. I also use FireFox 'Private Window' to help block a lot of ads.
"Let's Figgur it owt!" Just fix it (right), and make it work.....
Aah-OO-Gah! (and), "Happy T-ing!"
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Post by Jim Eubanks » Thu Feb 07, 2019 5:21 pm
Even when I check remember me, I have to log in again every time I start the computer to be able to post. Something is not right because on all the other sites I get on, once you log in and check remember me, you do not have to log in again. Hopefully someone will fix this glitch.
Marv K
First Name: Marv
Last Name: Konrad
Post by Marv K » Thu Feb 07, 2019 6:19 pm
-Jim-
Have you cleared your cache of cookies, or deleted the history?
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Thu Feb 07, 2019 6:37 pm
I had to log in several times in the past couple days also. Last evening and today has been ok. Back to normal.
Last Name: Hjortnaes
Post by DHort » Thu Feb 07, 2019 7:03 pm
Jim I can login when I first get on. If I want to post something I have to login again. So I write my posting, hit submit, and login comes up. If I post again on another topic I have to login again. Strange.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Post by Charlie B in N.J. » Thu Feb 07, 2019 9:33 pm
I too have to log in whenever I leave & come back. Tried remember me & bookmarking while signed in. Nothing works. On android
(pad) or Win 10 (lap top). Also I've noticed a very marked increase in junk mail since working to get the new forum useable for me. I'm talking 1 or 2 a day up to (now) 15 or 20 daily. The only changes I've made are adapting to the new Forum. Brought it to Chris' attention.
AdminJeff
First Name: Jeff
Last Name: Stevenson
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Post by AdminJeff » Thu Feb 07, 2019 9:38 pm
We’re working on it! Still no resolution, but I’m not giving up...
Jeff
Assistant WebSite Admin
www.modeltregulators.com
www.modeltstarters.com
Guest
Post by Guest » Sun Mar 31, 2019 6:31 am
Its still not "remembering me". Hope you get it fixed soon.
Last bumped by Anonymous on Sun Mar 31, 2019 6:31 am.
