Avatar's
Topic author - Posts: 132
- First Name: Kevin
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
Avatar's
Are the avatar's turned off or did I turn them off somehow with out knowing it ? They aren't showing up on my account.
- Last Name: Hanlon
Re: Avatar's
I can see your coupe.
- First Name: Kevin
Re: Avatar's
Thank you Ruxstel24, all I see on my computer for both my avatar and yours is a little page with green on the bottom. Clicking on it doesn't change anything, but I must have changed something on my computer with out knowing. I'll look tomorrow to see if I can find where to change it back.
- First Name: G.R.
- Last Name: Cheshire
Re: Avatar's
I'm not seeing avatars either. I reloaded mine but I still dont see anyone elses
- First Name: Jeff
- Last Name: Stevenson
- * REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Re: Avatar's
I found the problem. I hadn't restored them from a backup after I had to completely rebuild the site.
If they are still missing in the morning (Im doing a restore now), just upload your avatar image again. that will fix it.
Jeff
Jeff
Assistant WebSite Admin
1921 Model T Touring, 1930 Model A Roadster
Voltage Regulators, Starter & Generator Repair & Parts manufacturing
www.modeltregulators.com
www.modeltstarters.com
