post a pic?
Can’t log in? Having a problem with the Forums? Have a question about how something works? Get support here.
Barteldes
First Name: Bill
Last Name: Barteldes
* REQUIRED* Type and Year of Model Ts owned: 1924 Coup
post a pic?
Post by Barteldes » Fri Oct 11, 2024 9:25 pm
How do i put a picture in comments. i tried to copy and paste but that didnt work.
BIll B
No matter how you shake and dance the last few drops go down your pants.
RVA23T
Last Name: C
Re: post a pic?
Post by RVA23T » Fri Oct 11, 2024 10:15 pm
What are you using to do you posting?
PC?
Mac?
Smart Phone?
or a fruit (iphone)?
AND how familiar are you with editing a photo on your preferred posting device? most times all it takes is a crop or rotation to make photos post-able here.
Everything works in theory.
Reality is how you determine if something works or not.
Barteldes
First Name: Bill
Re: post a pic?
Post by Barteldes » Sat Oct 12, 2024 1:36 am
i have a pc took the lpic with my iphone and emailed it to my pc, copied it to desktop and tried to copy paste into the forum comment.
BIll B
RVA23T
Last Name: C
Re: post a pic?
Post by RVA23T » Sat Oct 12, 2024 9:07 am
Instead of cut & paste, you will need to use the attachments option:
After the attachment is uploaded and the GREEN CHECKMARK is present:
And to have the picture placed through out the body of your text, use "PLACE INLINE" after the curser is behind the text you are emphasizing.
Like this 1925 RPU:
1925 Roadster Pick-up
RVA23T
Last Name: C
Re: post a pic?
Post by RVA23T » Sat Oct 12, 2024 9:12 am
Same Files, with out "PLACE INLINE" use. They will post in the same, top down sequence, they are listed in the attachment list.
RVA23T
Last Name: C
Re: post a pic?
Post by RVA23T » Sat Oct 12, 2024 9:18 am
Want to post just a picture, without dealing with the minimum text/letter requirement?
Simply upload the files and use the "PLACE INLINE" button I added a "FILE COMMENT" that will appear under the photo:
RVA23T
Last Name: C
Re: post a pic?
Post by RVA23T » Sat Oct 12, 2024 9:23 am
25 RPU #'s
25 RPU #'s
RVA23T
Last Name: C
Re: post a pic?
Post by RVA23T » Sat Oct 12, 2024 9:54 am
Your file will not attach if you see the yellow triangle VS the green check:
You will need to edit the picture and resave it in order to upload to the forum.
Sometimes a simple crop down to the original file/photo will fix it, using the rotate might fix it, making color, tint, tone type of edit will help, and there are options to resize smaller but that is dependent on your editing software.
Mark Nunn
Last Name: Nunn
Re: post a pic?
Post by Mark Nunn » Thu Nov 14, 2024 8:56 am
Photo test
RVA23T
Last Name: C
Re: post a pic?
Post by RVA23T » Thu Nov 14, 2024 7:25 pm
Looks like an Error, it removed one of your pistons!!! :D
