mySQL is locking on server
Can’t log in? Having a problem with the Forums? Have a question about how something works? Get support here.
ChrisB
First Name: Chris
Last Name: Brancaccio
Post by ChrisB » Tue Jan 15, 2019 9:48 pm
I have disabled Private Messaging to see if this is the problem.
We have also had quite a few problems with Private Messaging with messages not sent or sitting in Outbox.
You can email a member if you click on name you will see Email under contact member.
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
Ruxstel24
Last Name: Hanlon
Re: mySQL is locking on server
Post by Ruxstel24 » Tue Jan 15, 2019 10:06 pm
I saw the forum was down this morning also.
FWIW, I've had no issues with getting PMs.
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Tue Jan 15, 2019 10:13 pm
I also tried a couple members "contact member" and nothing is there ?
Walter Higgins
First Name: Walter
Last Name: Higgins
* REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout
Post by Walter Higgins » Tue Jan 15, 2019 11:19 pm
Correct me if I am wrong, but I thought with phpBB that messages sit in the Outbox until they are read? Once read they are moved to Sent.
John.Zibell
Last Name: Zibell
Post by John.Zibell » Wed Jan 16, 2019 8:11 am
Correct Walter. Also the recipient isn't notified by email as a default setting. You have to go into your profile and select being notified by email. This way messages can sit in an outbox for a long time.
1926 Tudor
Don D
First Name: Don
Last Name: Demio
* REQUIRED* Type and Year of Model Ts owned: 1919 T
Post by Don D » Wed Jan 16, 2019 8:31 am
Chris,
Thank you for all your work to get the new forum up and running. You are appreciated for all your efforts as we explore the new system and features this system provides. As with all our Model T's there is always something that needs attention and we have to be patient and work together to get things running smoothly. I'm sure you have lost much sleep over this conversion. WE NEED TO SHOW YOU RESPECT AND UNDERSTANDING.
I hope you know there are many of us who have the old wood-fired laptops with the "Hickory Smoke" flavor to keep us calm while we who are analog struggle in this digital world.
Have a great day,
Dom
pdgriesse
First Name: Paul
Last Name: Griesse
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1924 touring
Post by pdgriesse » Wed Jan 16, 2019 9:45 am
I had that sql locking on server problem----Fixed it by going to RECOVERY on the control panel and resetting my computer to previous day recovery. That took care of it---all is well now. Paul
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Wed Jan 16, 2019 11:58 am
With a phpBB board, the outgoing message sits in the Outbox until the recipient logs into the forum and opens his mailbox.
1924 Touring
Last Name: Strange
Post by CudaMan » Wed Jan 16, 2019 12:02 pm
Thanks for that info, now I don't have to wonder why my PMs are sitting in my outbox so long! :)
ChrisB
First Name: Chris
Post by ChrisB » Thu Jan 17, 2019 10:46 am
We have talked to our host and they have found nothing unusual in our MySQL setup.
We are thinking of turning messaging back on to try and find out what is causing the problem.
We will make a post to this thread when we do.
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
Post by Mark Gregush » Thu Jan 17, 2019 11:16 am
Thanks Chris. Right now I can not send any messages. It was working fine at my end, both sending and receiving.
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Thu Jan 17, 2019 11:21 am
Yeah same here... I had no issues with PMs.
Thanks for your continued efforts Chris.
mtfcaadmin
Site Admin
First Name: Chris
Post by mtfcaadmin » Thu Jan 17, 2019 12:02 pm
OK everyone messaging has been turned back on
10:01 mountain time
Post by Mark Gregush » Thu Jan 17, 2019 12:10 pm
Great! A very BIG thank you for the work you guys are doing.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Thu Jan 17, 2019 12:36 pm
Thanks Chris !!!
Respectfully Submitted,
Be_Zero_Be
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Thu Jan 17, 2019 4:01 pm
:D
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Fri Jan 18, 2019 11:58 am
Locked out twice. Last time was this morning. Comes back by itself. Made no changes beyond adding an avitar days ago.
ChrisB
First Name: Chris
Post by ChrisB » Fri Jan 18, 2019 2:27 pm
Doesn't come back by itself, your admins are on the job 24/7 :shock: :shock: :shock:
Chris & Jeff
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
AdminJeff
Post by AdminJeff » Fri Jan 18, 2019 7:08 pm
There was just another failure at just after 4pm. I have found a permanent solution but its going to take a couple of days to test and then deploy.
Everyone please bear with us. I'm going to keep posting to see if I can find any patterns.
Jeff
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Fri Jan 18, 2019 7:14 pm
It dropped out about 6:35 eastern time...
Post by Wayne Sheldon » Fri Jan 18, 2019 7:25 pm
I do not know if this helps or not. Yes, it was off (error codes as you mentioned) just several minutes ago. I also had trouble with this site lasnight around midnight Califunny time. I also had troubles with AACA's forum last night. I do not recall which one, but I got "503 error" codes on one of them last night. While we were off, in the past twenty minutes, I went to AACA again for a few quick looks, and also experienced am "SQL" error with them. Interesting to me that both sites were having issues in the same time-frame, twice.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Post by Charlie B in N.J. » Fri Jan 18, 2019 7:51 pm
Sorry Chris. I didn't actually mean it "cured" itself. I realise you're on top of it & it's appreciated.
AdminJeff
Post by AdminJeff » Fri Jan 18, 2019 11:51 pm
It’s a Total coincidence! Unless they use the same hosting provider.... what is the website? I can uncover who they use. If it’s the same company....hmmmm.
Post by Steve Jelf » Fri Jan 18, 2019 11:58 pm
Post by Wayne Sheldon » Sat Jan 19, 2019 12:48 am
Yes and thank you to Steve J for answering the question.
Thank you to all our administrators and moderators for the work you do. I did communications systems contracting for a living for about thirty years. I know how infuriating it can be to sort out the hundreds of minutiae involved in making these things work, any one of which could be causing some silly problem.
AdminJeff
Post by AdminJeff » Sat Jan 19, 2019 1:21 am
It’s like a puzzle. One piece falls into place and you go searching for the next one. Or you wait for the the next clue to show itself. Ion if all else fails, you force a solution (which I’ll be doing tomorrow). I studied engineering to get the discipline of how to solve problems engrained in my brain. Not to be a circuit jockey. As a CEO, that skill has served me well. I often use it to great effect on complex IT issues and thankfully I have deep working knowledge of the systems we use for our forums. That doesn’t mean crap when thing go wonky though, and things are going wonky!
Humbled,
Jeff
Post by Rich Eagle » Sun Jan 20, 2019 8:08 am
It just blipped a minute ago. 6:04 MT OK now. disregard Email.
