I’ve been trying for three days to load the old forums across multiple devices and haven’t been able to do anything. Is it something I’m doing or have they been taken down?
Brad
Old forums not working.
TFan
- First Name: Jim
- Last Name: Riedy
Re: Old forums not working.
Same here in Northern Ohio, Can't access any of the old Forums. Jim
I even tried by subject, exp Rocky Mt brakes, nothing. If they are gone for good would be sad loss. There are search engines that can look for anything that has been posted on the web even if no longer hosted, but that is out of my league. It was the same with the International site, all the links that I had saved were lost, along with all the info on them. I know I go back to the old postings when looking for information that had been posted in the past.
As of this AM I was able to do a google search of old postings. It may be up and down as Chris/Jeff sort things out. Thank you
Oh PS, if you look at this posting, the last entry was July 10th, 2019
http://www.mtfca.com/discus/messages/82 ... 2784690#MB
So it is still in use or was as of the 10th.
AdminJeff
Theres a bug that lets posts happen. Trust me, I will fix that bug. The old forums software is no longer supported. If you need to search them, use a search engine like google.com.
Jeff
Jeff
