Winfield SR
mike penserini 1
Winfield SR
Jeff, If i was able to get on the forum I would post the original SR setup sheet. You might be able to find it on the NWVS site.
AdminJeff
- Last Name: Stevenson
Re: Winfield SR
yes, I already have it!!mike penserini 1 wrote: ↑Mon Jul 15, 2019 12:40 pmJeff, If i was able to get on the forum I would post the original SR setup sheet. You might be able to find it on the NWVS site.
Assistant WebSite Admin
www.modeltregulators.com
www.modeltstarters.com
AdminJeff
Re: Winfield SR
And because you just posted this, you, Mike Penserini, ARE on the forum....mike penserini 1 wrote: ↑Mon Jul 15, 2019 12:40 pmJeff, If i was able to get on the forum I would post the original SR setup sheet. You might be able to find it on the NWVS site.
Jeff
Last bumped by Anonymous on Fri Aug 09, 2019 12:11 pm.
