Anderson Timer
Topic author - Posts: 254
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Anderson Timer
Looking thru some old timers I noticed the Anderson Timer has a smaller diameter circle for the contacts. What does the roller assembly look like that attached to the cam compared to other roller assemblies?
- First Name: Adrian
- Last Name: Whiteman
Re: Anderson Timer
Anderson timers use a 'flapper' rather than a roller. The flapper swipes across the contact spot in the timer instead of 'rolling' or 'rubbing' around the edge as regular timers with rollers or brushes do.
It seems you either like them or you don't. I like them and have had good running experience (i.e. no problems, always work, last a long time).
Anderson flapper:
Roller:
Brush:
Anderson flapper:
Roller:
Brush:
- First Name: Ron
- Last Name: Jackson
- * REQUIRED* Type and Year of Model Ts owned: 1915 roadster 1925 coupe 1923 Tudor 1927 speedster
- Board Member Since: 2014
Re: Fronty head
Is there a group of guys that have parts and just talk or is there a club where I can talk to these guys that run frontys
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1924 TT, 1923 Touring, 1927 Tudor, 1915 Roadster
Re: Anderson Timer
I have an original Anderson timer with all the company patient data embossed that Frank Fenton rebuilt for me like 15 years ago, and it works like a champ. Frank was reproducing the Anderson Timer back when he and I were on the MTFCI board of directors.
- First Name: Mike
- Last Name: Kossor
Re: Anderson Timer
Dennis, a more recent approach is a Vane actuator used by the I-Timer. Rather than a roller, flapper or brush; the 4 magnets tell the Timer which coil to activate and the windows cut in the outer diameter tell the timer when to activate the coil without any physical contact so its maintenance free and never wears out. A single sensor is used to detect window openings so the Vane actuator is immune to timing cover misalignment about the CAM (concentricity) to minimize coil to coil timing variations.
