Weak mag ?!?
Rich Bingham
First Name: Rich
Last Name: Bingham
Weak mag ?!?
Post by Rich Bingham » Mon Jun 08, 2020 11:03 am
In the thread on the self-destructing magneto, R. V. Anderson commented that a weak mag could indicate cracked magnets. How weak is weak ? What’s the best test for magneto strength ? Do you need instruments ?
My Lizzie starts readily on battery when cold, but I haven’t had a similar response cranking on mag and haven’t worked at it, it’s just too easy on bat ! On the other hand, once warmed up, a quarter turn on mag, and she fires right off. Comments, please ?
"Get a horse !"
Les Schubert
First Name: Les
Last Name: Schubert
Re: Weak mag ?!?
Post by Les Schubert » Mon Jun 08, 2020 1:46 pm
An AC voltmeter is useful.
Re: Weak mag ?!?
Post by RajoRacer » Mon Jun 08, 2020 3:05 pm
Analog at that - have heard digital doesn't like the output ?
Ron Patterson
Re: Weak mag ?!?
Post by Ron Patterson » Mon Jun 08, 2020 5:43 pm
FunProjects St. Louis magneto tester is the best way to measure the output of a Model T magneto.
St Louis Magneto Tester.docx
(13.06 KiB) Downloaded 142 times
