Frame front corner bracket shape?
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Mon Jun 08, 2020 10:42 am
Hi, I am trying to figure out what the shape of this frame front corner bracket is supposed to be?
Re: Frame front corner bracket shape?
Post by Mark Gregush » Mon Jun 08, 2020 11:55 am
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Mon Jun 08, 2020 12:09 pm
Those are 26/27 fender supports and depending on the style of Speedster you are building can be set flat for some funky headlight mounts.
Hank
Post by Wayne Sheldon » Mon Jun 08, 2020 8:47 pm
'26/'27 model frame to fender mount, been butchered and bent. Earlier than '26 did not have such fenders or mounts. Depending upon the speedster you plan to build, you could straighten and repair them, or further alter and use them. or cut off even with the outside of the frame rail and treat it like an earlier frame.
