motometer
Topic author - Posts: 11
- First Name: jon
- Last Name: ewing
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T touring
motometer
Motometer on 1916. Installed and sensor does not reach water. Is it supposed to read water temp or the air in the chamber above the water?
- Last Name: Stroud
- Board Member Since: 2011
Re: motometer
Jon, it isn't supposed to reach the coolant level, you are correct. It reads the air(steam) temp. Dave
1925 mostly original coupe.
- First Name: Dallas
- Last Name: Landers
Re: motometer
Does not need to reach the water.
