Tube valve stem cut off
jonathan
First Name: jonathan
Last Name: Delancey
* REQUIRED* Type and Year of Model Ts owned: 1919 Roadster
Post by jonathan » Sun Jun 14, 2020 12:28 pm
Besides low air pressure, what would cause a valve stem to shear? Tire pressure was 60 psi. The stem was still perfectly straight and stuck in the rim! I am using a flapper also, could that be a problem? Have about 2000 miles on tire and tube.
Last Name: Gregush
Re: Tube valve stem cut off
Post by Mark Gregush » Sun Jun 14, 2020 12:47 pm
Front or rear? Are your rims powder coated, painted or?
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
* REQUIRED* Type and Year of Model Ts owned: 1916 TOURING
Post by BE_ZERO_BE » Sun Jun 14, 2020 12:49 pm
Most likely, the tire and tube rotated on the rim.
What kind of tire was it?
What kind of rim was it.
There are certain combinations of tires and rims that are prone to tire slippage.
I have had this problem since 2007.
Respectfully Submitted,
Be_Zero_Be
I drive a Model T ... Microseconds don't matter :D
jonathan
Last Name: Delancey
Post by jonathan » Sun Jun 14, 2020 12:53 pm
Front drivers side. Hayes rim and riverside tire. Rim painted not powder coated.
Post by Steve Jelf » Sun Jun 14, 2020 12:57 pm
What brand of tube?
Post by Rich Eagle » Sun Jun 14, 2020 1:03 pm
I lost several like that in a particular run of Firestones in the 80s. All were at high speeds downhill. I did not use flaps then but do now and haven't had that problem with different tires since.
jonathan
Last Name: Delancey
Post by jonathan » Sun Jun 14, 2020 1:05 pm
Hartford tube made in China
Post by Steve Jelf » Sun Jun 14, 2020 1:55 pm
That's a surprise. I was expecting Custom Classic. I haven't had that problem with Hartfords, but that may be because I replace the rubber stems with metal.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Mon Jun 15, 2020 10:18 am
If this is the flapper you were using, it could be a problem.
Post by Original Smith » Mon Jun 15, 2020 11:35 am
Try using a flap instead of a flapper!
Post by DanTreace » Mon Jun 15, 2020 2:45 pm
Could be the issue, those rubber valve stems have a taper and can stick in place too soon, and not be fully up into the rim. That can cause the tube to be 'suspended' just beneath the valve stem, and allow the tube to bunch just a bit, and be like a loose pocket under the stem when aired up.
Also, don't see much remains of talc on the tube or around the stem, unless you wiped it clean on removal. Talc powder is needed to provide lube to the rubber surfaces and prevent chafing that can cause valve stem/tube interface issues.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Mon Jun 15, 2020 4:38 pm
I air them up with no valve core in place and allow all the air to escape about 5 times before installing the valve core and final airing up. That allows the tube to move around inside of the casing and self align itself so there is no stress or bunching on the stem.
Odds are fairly good that your issue was the stem being stressed internally in some way.
Alan Long
First Name: Alan
Last Name: Long
Post by Alan Long » Mon Jun 15, 2020 11:40 pm
Yes, we all install Tubes with good intentions and care but nobody really knows what’s going on inside the Tyre!
Who would check or even know how to check if the Tube is the correct size and not manufactured too large or small with
over stretching or folds being a issue. Another reason to us Blockley. The Owner of the Business told me his Tubes are correct
and you can install them with knowledge they are the correct fit in the Tyre. Not suggesting this is the issue
with the initial question. Alan
