Bearing clearance on Ford TT axle
bigbull
First Name: Stephan
Last Name: Schaller
* REQUIRED* Type and Year of Model Ts owned: TT Truck 1925 and Touring 1923
Post by bigbull » Fri Jun 19, 2020 4:28 pm
Hi,
We rework a Ford TT Ruckstell rear axle. We have the "The Ruckstell Axle" book but can't find any information about the bearing play. Can someone give us some information? Thanks Stefan[image][/image]
HPetrino
First Name: Henry
Last Name: Petrino
Re: Bearing clearance on Ford TT axle
Post by HPetrino » Fri Jun 19, 2020 5:40 pm
I don't believe there are any clearance guidelines or "settings". I just ran mine tight enough to eliminate excessive movement being sure everything moved freely and that's it. I may be wrong, but it's been working fine for 18 years since had it apart.
