Stretching Clincher tires
Topic author - Posts: 310
- Last Name: Hand
- * REQUIRED* Type and Year of Model Ts owned: 1912 open express, 1920 touring, 1926 tudor-lisenced and insured, 1921tt project 1922 fendered chassis, 192x tt dootle bug 192xengine w/winch projects
It is summertime & the weather is hot, time for me to stretch some older 30 x 3 1/2 tires to mount for a roller chassis. I am looking for the mounted size car tire to use to stretch the old tire I had seen it in years back on the Forum but have not found it today. I believe it was like 165/75/14 or maybe 175/75/14?
Re: Stretching Clincher tires
Here is that post:
By Allan Bennett on Wednesday, May 05, 2010 - 11:37 am:
Old hard tyres have often shrunk. Borrow you wife's dressmaking tape and measure the inside circumference and compare this to the circumference of your rim and you will see what you are up against. Peter Kable is right when he says they need to be stretched first. I stretch them by levering them over an uninflated 165 x 14" tyre and then inflating the tyre. Sometimes it takes two steps, using a slightly higher profile tyre for the second stretch. You might have to leave them for a week or two to achieve enough stretch. Sometimes they will break the bead if they are too hard.
When I fit them I use tyre shop lubricant. It is a lot less messy than soapy water and does not dry out. I put a rim liner cut from an old 13" inner tube directly onto the rim, and fit a lightly inflated tube into the tyre. I fit both sides together, to avoid pinching the tube trying to lever each bead on separately. I use a portable third hand in the form of a clamp to hold both sides of the tyre in the rim at the valve. That leaves both hands free to work the tyre levers, working both ways around from the valve. At the end, one bead will go on first, leaving about 6-8" of the second bead to lever on at the end. All of this is done at waist height on benchtop.
A key to fitting any hard-to-fit BE tyre is tyre lever itself. Mine are 18" long, have the usual shallow curve at one end like the genuine T levers, and at the other end is a sharply cupped hook which is about the same profile as the edge of the rim. It is easy to get under the tyre bead and closely follows the rim edge as you lever, so keeping well away from the tube. Mine are German Dowidat brand and the hook end is about half as thick as the cheap oriental imports.
- Last Name: Hand
Dan, Thanks for the info, now the hunt for a mounted 165/75/14, getting hard to find. Pick n Pulls salvage yards already have the wheels & tires removed when the cars are placed in a yard. I do not need to measure anything I already know they have shrunk, I was able to get one apart this afternoon after setting in the sun. My Weaver Model E tire machine helps & my tire iron collection I have had for quite awhile. Thanks again. George
George, with the multiplicity of tyre sizes and profiles these days, there are likely to be other combinations which will work. Take your 30 x 3.5 tyre with you and try it on against whatever you can find. The higher the tyre profile the better, as this will expand more when you inflate it, so you get more stretch.
