Dayton wire wheel info
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Fri Feb 15, 2019 1:50 am
How do you remove the hub cotter keys? The keys rear and front they seem way down inside the hubs
Bob
E THOMAS
First Name: Erik
Last Name: Thomas
* REQUIRED* Type and Year of Model Ts owned: 1925 roadster pick up
Board Member Since: 2014
Re: Dayton wire wheel info
Post by E THOMAS » Fri Feb 15, 2019 6:42 am
On Rudge spline drive hubs, there is usually a small hole in the side, sometimes covered with a small screw.
Nv Bob
First Name: Bob
Post by Nv Bob » Fri Feb 15, 2019 12:03 pm
These are 6 pin drive 30x3.5 there is no hole or screw in the hub
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Feb 15, 2019 12:39 pm
The Buffalo hubs have the same condition...
Use a little tool, and a lotta patience!
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Fri Feb 15, 2019 1:37 pm
Add a 1/4" diameter thru hole in the hub that lines up with the keyway and the cotter pin hole in the axle. The added hole won't weaken the hub. Or do as Kevin suggested and just live with it. Needle nose pliers are your friend.
Post by RajoRacer » Fri Feb 15, 2019 3:54 pm
Yes - LONG needle nose !!!
Nv Bob
First Name: Bob
Post by Nv Bob » Fri Feb 15, 2019 10:58 pm
Thanks im going mark it and once off drill
Thanks guys
