Can’t remove roller bearing from driveshaft spool
Wwbbim
First Name: Jace
Last Name: Jensen
* REQUIRED* Type and Year of Model Ts owned: 1922 Roadster
Post by Wwbbim » Sun Jul 12, 2020 9:14 pm
The roller bearing on my driveshaft is stuck inside the spool. Is there any specific way to get it out? Something is blocking its way out the front of the spool and I know it’s supposed to be able to come out but i don’t know how to take it.
Re: Can’t remove roller bearing from driveshaft spool
Post by RajoRacer » Sun Jul 12, 2020 9:58 pm
That's the "thrust" bearing down there - use a block of wood & press it out.
