Model Ts
Model Ts
Post by Dollisdad » Sat Jul 25, 2020 11:46 pm
Chris Instness
First Name: Christopher
Last Name: Instness
Re: Model Ts
Post by Chris Instness » Sun Jul 26, 2020 12:36 am
Very interesting highly accessoried roadster. Looks like a 1914. Hard to tell, but are the splash sheilds indented to give extra foot room stepping into the car?
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Model Ts
Post by Kevin Pharis » Sun Jul 26, 2020 1:03 am
And I’m assuming that’s a front mounted electric starter... never seen that style before. Very cool👍
lmitch
First Name: Lee
Last Name: Mitchell
Re: Model Ts
Post by lmitch » Sun Jul 26, 2020 1:46 am
What is the chain spoke for? Third photo front wheel.
Re: Model Ts
Post by Mark Gregush » Sun Jul 26, 2020 1:49 am
Speedometer drive gear.
John E. Guitar
Last Name: Guitar
Board Member Since: 2012
Re: Model Ts
Post by John E. Guitar » Sun Jul 26, 2020 2:17 am
The building in the second photo:
A few more Wichita photos.
John E. Guitar
Last Name: Guitar
Re: Model Ts
Post by John E. Guitar » Sun Jul 26, 2020 2:39 am
I guess the thing on the front of the car in the second photo is part of the Everful Water System.
Last edited by John E. Guitar on Sun Jul 26, 2020 2:43 am, edited 1 time in total.
Jem
First Name: Jem
Last Name: Bowkett
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring #9267
Re: Model Ts
Post by Jem » Sun Jul 26, 2020 2:41 am
That bus is mind-boggling! How does a 20hp drag all that body along, let alone filled with passengers. Imagine if a bunch of kids rushed to grab the back seats - the front wheels would lift off.
Re: Model Ts
Post by Allan » Sun Jul 26, 2020 3:41 am
The bus is built on a chaindrive extension like a Smiths Form-A-Truck, so it will be very low geared. That will be the key to it being able to haul a load. There is till more of the body forward of the rear axle, so it shouldn't tip up.
I was wondering what year the tourer is in the second photo. At first glance I had it don as a 14 model with the forward folding windscreen, but then I noticed the fore-doors.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Re: Model Ts
Post by D Stroud » Sun Jul 26, 2020 6:39 am
Allan, I think the bus driver had to be very careful where the students sat, that thing is way back heavy even when empty, unless the body was built extremely light in the rear. JMHO Dave
1925 mostly original coupe.
Re: Model Ts
Post by Jerry VanOoteghem » Sun Jul 26, 2020 8:24 am
"Bus drivers over 300 lbs need only apply for this job"
Re: Model Ts
Post by Original Smith » Sun Jul 26, 2020 9:42 am
Keep them coming. I love those old photos!
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Model Ts
Post by Kevin Pharis » Sun Jul 26, 2020 11:38 am
When reading the article on the Everful Water System, it basically describes an overflow tank that also condenses the steam, and most likely siphons the captured overflow back into the radiator similar to modern systems but without pressure. No mention of any mechanism to perform the task.
This roadster has obviously been electrified, and sports accessory headlights and spotlight. Notice the lack of hand crank as well...? Could this not only be an accessory starter... but a starter generator combo unit?
old_charley
First Name: Bryan
Last Name: Ostergren
* REQUIRED* Type and Year of Model Ts owned: 1914 cut-off touring/pickup: 1922 Touring car: 1921 TT Dump Truck
Re: Model Ts
Post by old_charley » Sun Jul 26, 2020 11:53 am
Allan, the T in question looks to be a '12 with a '13 windshield mounted vertically. Note the support rods. they look to be '13 style but mounted more upright on this car than they would be on a '13.
HornsRus
First Name: Charley
Last Name: Shaver
* REQUIRED* Type and Year of Model Ts owned: 1913
Re: Model Ts
Post by HornsRus » Sun Jul 26, 2020 4:29 pm
on the late 12 the windshield is none ford issue. also check out the headlights.well used ford ha,ha. charley
kmatt2
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster’s,51 Mercury 4 door sport sedan, 67 Mercury Cougar
Re: Model Ts
Post by kmatt2 » Sun Jul 26, 2020 5:39 pm
The 1912 touri.g in the third picture has N J. 17 license, so it is in pretty good shape for a 5 year old car, must not be driven in the winter.
Re: Model Ts
Post by Dollisdad » Sun Jul 26, 2020 8:46 pm
The 12 in picture #3 appears to have a 09-10 type windshield with spring loaded, over center type hinges. The windshield mounting brackets have been changed to the even reach type, and because they are different they are relocated next to the stock location. The 13 style support rods are longer than stock ones to compensate for the vertical windshield. You can see the bolt head just ahead of the upper front door hinge. Also the car has 1915 front fenders. Notice the cross bead on the bottom side and with enlargement you see three flat head type rivets. The front lower trim of the radiator is missing. The headlights are slightly bent upward, with the lower part of the door flattened. Hand crank handle is missing off crank. Tells me someone ran into something and damaged the fenders, windshield, crank, radiator and headlights. Otherwise the car looks pretty clean.
HornsRus
First Name: Charley
Last Name: Shaver
Re: Model Ts
Post by HornsRus » Sun Jul 26, 2020 9:19 pm
one headlight is 12 one is 13.charley
Re: Model Ts
Post by Dollisdad » Sun Jul 26, 2020 9:57 pm
I completely missed that Charley. Also the front fender irons are the eyelet type to hook the top straps to.
