Ever seen one of these broken
Topic author - Posts: 46
- First Name: Cameron
- Last Name: Smythe
- * REQUIRED* Type and Year of Model Ts owned: 1925 Duncan and Fraser 1/2 ton pickup and a 1922 Sydney built steenbhoms tourer
[image][image][/image][/image]has anyone come across this type of breakage and if so what are the causes?
The pin was solid so it wasn’t a loose pin
- First Name: Donald
- Last Name: Conklin
- * REQUIRED* Type and Year of Model Ts owned: 1919 touring, 1923 depot hack, 1927 speedster
Re: Ever seen one of these broken
Torque tube not modified to accomodate a ball bearing 4th main
No but I have had one with the T-tube broke inside the casting at the other end. The radius rods kept it in place locked at the rivets where it had sheared.
- Last Name: Smythe
No mods all original
No pin gouge
And radius rods look good
No pin gouge
- First Name: Kevin
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
If the rear spring center bolt head broke or slipped out of the rear cross member and the rear axle, spring and all, shifted slightly it could have stressed the torque tube over time. Because the torque tube ball is held fast by the motor even a slight and unnoticed misalignment could stress the torque tube in the area that broke.
- Last Name: Strange
- Board Member Since: 2013
Too many burnouts!
- Last Name: Juhl
I didn't see any grease cups.....
- First Name: Howard
- Last Name: Tomlinson
I haven't seen one broken, but I did take one housing apart where the universal pin evidently had backed out and scored the inside of the housing. Being that that area is already pretty thin a similar break could have happened.
- First Name: David
- Last Name: Menzies
- Board Member Since: 2012
Just throwing out a thought, the break in that location would be developed by engine torque, the bolts that sandwich the rear part of the torque tube to the diff housing are 3/8" + 1/32 or 13/32" they are referred to as special bolts, if they were ever replaced with incorrect 3/8" bolts this could allow unwanted movement, just a thought.
- First Name: Jem
- Last Name: Bowkett
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring #9267
The nose of the torque tube is free to move around in the ball cap to accommodate suspension movement. If that cap is dry or seized for some other reason, something has got to give.
Were you using a shim to take up for wear in the ball/retaining ring? Too much shim can lock up the ball joint and may cause this.
