Wheeler Schebler carburetor FAX8 questions
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Post by Bruce Compton » Sun Aug 02, 2020 1:33 pm
Does anyone have an opinion comparing these Wheeler-Schebler carbs to a Stromberg OF carb. as to power , idle , economy, availability etc. ? Thanks in advance: Bruce
IMG_5193 (2).JPG (70.33 KiB) Viewed 1436 times
Re: Wheeler Schebler carburetor FAX8 questions
Post by Mark Gregush » Sun Aug 02, 2020 2:19 pm
I have run one like it. This style does line up with the Ford hot air pipe. The valve at the bowl is an enriching needle for starting or as needed for richer mixture. As far as performance, my OP is they mirror the Strombergs but not as common. viewtopic.php?t=6568
