Modern rear axle seals
Mountainrider
First Name: Neil
Last Name: Haywood
* REQUIRED* Type and Year of Model Ts owned: 1915 roadster
Post by Mountainrider » Thu Aug 20, 2020 8:43 pm
The press in oil seals on my modern outer axle seal from Lang’s got chewed up. Could some one look at theirs a send me the seal #. I matched the O rings but having trouble finding the axle oil seal.
Just looked up the invoice. Bought back in 2001
Kerry
Last Name: van Ekeren
Re: Modern rear axle seals
Post by Kerry » Thu Aug 20, 2020 11:40 pm
The ones that are available from the vendors today don't look like yours, but may still use the same seal?? The seal # is POS26407 TF marked PEER TAIWAN.
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Aug 21, 2020 12:23 am
Hi Neil,
If the OD is 1.576 or 40mm & .306 or8mm try tc 26 40 8 4 IVAK These seem to work well in the 2510N & the 2510NB seal sets I have. I know they are made in China but they were all my seal house had that matched up.
Mountainrider
First Name: Neil
Last Name: Haywood
Post by Mountainrider » Sat Aug 22, 2020 7:26 am
Could only find 26-40-7 from any local venders. Found these on eBay. They are discontinued. If they work I’ll find another set to have on hand.
Chaffins
First Name: Herbert
Last Name: Chaffin
* REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1911 touring, 1913 roadster, 1914 touring
Post by Chaffins » Sat Aug 22, 2020 3:33 pm
These modern seals do not work well. the seals are very narrow and will not follow the axle as it moves off center from bearing and axle wear. this causes a seal gap on the opposite side that results in a leak. Our modern seals are a boot type seal and will follow the axle movement. Glen
Mountainrider
First Name: Neil
Last Name: Haywood
Post by Mountainrider » Sat Aug 22, 2020 8:05 pm
Will your replacement seal fit my housing. Outer diameter is 40 mm.
