aughhh...nuts
NU2theT
Last Name: Wendt
aughhh...nuts
Post by NU2theT » Tue Sep 01, 2020 8:25 pm
Getting the front and rear bumpers back on the Fordor, thanks Jeff Humble. I wanted to find the 9/16-18 square nuts that hold the outer bumper clamps to the backing plates and found them item #56NSQ8/fine @ Ziegler bolt in Canton Ohio.
1-800-362-0628
Last Name: Humble
Board Member Since: 2006
Re: aughhh...nuts
Post by Humblej » Thu Sep 03, 2020 8:10 pm
Scott, I do not remember those being square nuts, I think they were fine thread hex nuts I took off. Please post pictures when you are done.
NU2theT
Last Name: Wendt
Re: aughhh...nuts
Post by NU2theT » Fri Sep 04, 2020 8:23 pm
Jeff you are right the ones I got from you are regular hex nuts, the reproduction sets have square nuts. Will stick with the regular hex nuts as I recently talked with someone @ Ziegler after trying to order based on their web site info as square nuts available in 9/16-18 but are no longer available.
I just dropped the bumper face bars off to powder coat along with a set of wire wheels, should have them back in 3-4 weeks and will post pictures then.
kelly mt
Last Name: Kelly
Re: aughhh...nuts
Post by kelly mt » Fri Sep 04, 2020 11:59 pm
Check McMaster-Carr. Might have what you need.
https://www.mcmaster.com/nuts/square-nuts/
NU2theT
Last Name: Wendt
Re: aughhh...nuts
Post by NU2theT » Tue Sep 22, 2020 8:34 pm
After a long search for originals, bumpers back from powder coating and installed. Thanks again Jeff Humble and MTFCA classified.
Re: aughhh...nuts
Post by Norman Kling » Tue Sep 22, 2020 8:52 pm
I have not seen bumpers power coated or painted. The original ones I have seen were nickel plated,and many have Chromed them.
NU2theT
Last Name: Wendt
Re: aughhh...nuts
Post by NU2theT » Wed Sep 23, 2020 6:04 am
Well now you have :lol: If you look real close @ the last picture my 39 has the bumpers powder coated as well. Have a nice day and drive your T frequently.
Last Name: Humble
Re: aughhh...nuts
Post by Humblej » Wed Sep 23, 2020 7:30 am
Nice to see them back in use again. I do like the look of long bar rear bumpers. Wish they had fit my coupe.
