Rear Axle Shafts
Rear Axle Shafts
Post by Original Smith » Sun Sep 06, 2020 10:53 am
I just found out from Randall Anderson, that Snyders is now selling stock rear axle shafts. Good to hear!
Adam
First Name: Adam
Last Name: Doleshal
Re: Rear Axle Shafts
Post by Adam » Sun Sep 06, 2020 11:14 am
Has to be over a year now. Maybe even longer...
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Sun Sep 06, 2020 1:29 pm
Hey, for me, that's practically yesterday.....
bobt
Last Name: Thompson
Post by bobt » Sun Sep 06, 2020 4:17 pm
Are they original?
jab35
Last Name: Bartsch
Post by jab35 » Mon Sep 07, 2020 2:12 pm
Bob: They are reproductions made from 4140 steel, heat treated to Ford specs & surface ground, and are Ford dimensions EXCEPT 1/16" longer. They have a laser-etched trade mark, "GN" inside an oval mid-length on the axle. The portion inboard of the gear keeper is a slip fit on the gear so it's easy to align the gear and key way, outboard of the keeper grove the axles are same diameter as bearing surface (1.062") which is approximately a 0.001" interference fit with original Ford gears. I found the press fit required about 1,700 pounds to install the used Ford gears. The new woodruff keys (nominal 0.250" thick, measured 0.2490") were tight in both axle and gear keyways, but did not require 'press' fitting.
Some have recently commented the hub end keyway is too narrow. I measured the axle hub keyway width and got 0.2465". This is a spare axle so I have not installed it or mounted a hub to it--yet. Hope this helps, jb
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Mon Sep 07, 2020 4:24 pm
Actually, the ones Larry is speaking of are totally stock in that they are made exactly to original Ford specs, as I understand it. They don't have the extra 1/16". Therefore they would be perfect for my NOS hubs. Also they are made from 4130 steel, not 4140 as the added-length units are.
jab35
Last Name: Bartsch
Post by jab35 » Mon Sep 07, 2020 10:17 pm
RV Where do you get those? Thanks, jb
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Tue Sep 08, 2020 10:01 am
Post by Original Smith » Tue Sep 08, 2020 10:39 am
It's amazing how many that read this forum don't understand what they are reading!
Post by Jerry VanOoteghem » Tue Sep 08, 2020 12:02 pm
That's because some people actually come here to LEARN, (versus showing off how much they already know), and not to be chastised or insulted because they haven't spent 50 years in this hobby. Too bad that those with a huge amount of valuable knowledge have to use it to belittle others, rather than to educate.
Barry Loucks
First Name: Barry
Last Name: Loucks
* REQUIRED* Type and Year of Model Ts owned: 13, 22
Post by Barry Loucks » Tue Sep 08, 2020 1:47 pm
THANK YOU JERRY!!!!!!
