Help identifying the year of this T
Tmodelt
Topic author - Posts: 167
- First Name: Kim
- Last Name: Wynn
- * REQUIRED* Type and Year of Model Ts owned: 1923 Roadster & 1927 Speedster
Can any of you smart members help identify the year of this T Touring? The couple sitting on the running board are my maternal grandparents before they were married. They were married in 1920. The fellow in the driver's seat is my grandfather's older brother. Chaperone maybe?
Re: Help identifying the year of this T
I would only guess 1917 to 1922. But likely before 1919 when demountables and a starter were optional and would not likely have cowl lights. The smart ones may be able to do better than that.
Altair
- Last Name: Menzies
- Board Member Since: 2012
Could be a movie prop.
By the looks of the right wheel the car might have had something to happen to it. The wheel looks like it’s in a rut and might have a broken hub by how it’s leaning outward. Maybe it’s just the way the photo was taken causes it to look the way it does. There is a story behind the photo I’ll bet!
I would date the car probably a 19 or before because of the cowl lights.
Tmodelt
- First Name: Kim
- Last Name: Wynn
I wouldn't be surprised in the least if they had a wheel break. They lived in east central Illinois at the time this photo was taken. The driver (my grandpa's brother) has a somewhat sour look on his face. Thanks for all the help so far.
I believe I see the earlier style spring clip, so I'll say 17-20.
After another look I believe I see the wishbone above the axle. A shadow under the spring and then white as it goes behind the license plate. That would make it '17 or '18.
Tmodelt
- First Name: Kim
- Last Name: Wynn
You folks have better eyes than I do and a lot more knowledge.
- Last Name: Juhl
The position of the windshield hinge appeared in later 1917. The bow sockets look square which along with the previous comments would make it 1918 or non-starter 1919 (maybe
