Routing Distributor wire
Mustang1964s
Topic author - Posts: 272
- Last Name: Bourgeois
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
I am thinking of re-routing the wire to the distributor to match the path of the wiring loom.
Is this going to cause issues with the length of the wire extended?
What gauge of wire should I use?
The coil is up on the firewall on the drivers side.
Mustang1964s
Re: Routing Distributor wire
I purchased 12 gauge wire to do the run around front and down the side.
The wire on the condenser seems to be very small.
Hope this works.
Hope this works.
Les Schubert
- First Name: Les
- Last Name: Schubert
I would seriously consider relocating the coil to the front of the engine, probably to the rh water outlet bolt. I’ll look for a picture of mine.
Les Schubert
- First Name: Les
- Last Name: Hjortnaes
My coil is on the passenger side of the firewall. There is a loop of string hanging from the rod under the hood that all the wires run through. Never a problem.
Mustang1964s
I really like the idea of relocating to the passenger side.
The only issue might be the heat off of the exhaust manifold.
I will take a look at it tomorrow.
jsaylor
- Last Name: Saylor
Made a bracket to mount the coil on the water outlet bolt.
- Attachments
- coil mount (1).JPG (38.78 KiB) Viewed 2029 times
