Back wood for 23 touring.
Topic author - Posts: 66
- First Name: Thomas
- Last Name: Black
- * REQUIRED* Type and Year of Model Ts owned: 1923 touring
Any place that sells individual pieces of wood? I'm just needing the curved piece of wood that goes around the top back of a 1923 touring. The rest of my wood is fine. Thanks
- Last Name: Black
Re: Back wood for 23 touring.
Check in with Jon Anderson - R.V.'s brother - R.V. follows this Forum.
Go to classicwoodproducts.
They are located in North Carolina and make wood frame kits and pieces for Model T’s. They sell the individual back wood pieces for Tourings also.
Hope this helps
Hope this helps
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- Board Member Since: 2014
Jonathan Anderson will make that for you. Best if you call him, 716-499-7255
Even the catalogs sell just the tack rail. I think you will need the whole unit, not just the curved parts. Just buying the curved parts does not mean they will match up to the rest of it.
That bent rail is best made from steam bent timber to avoid the short grain across a cut curve. You can do it yourself by laminating strips of plywood using the body as your former.
Hope this helps.
Hope this helps.
