1919-25 Switch Plate
SurveyKing
First Name: Daniel
Last Name: Snell
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
Board Member Since: 2014
Post by SurveyKing » Wed Sep 16, 2020 2:15 pm
Does anyone know of a Ben Martin who repairs ignition switches, the number I have for him does not work. I am wanting someone who knows how to restore the plate and the white lettering thereon and I have heard that he is the guy. If someone else is out there that does this kind of work please let me know. Thanks
DanielSnell2@twc.com
Re: 1919-25 Switch Plate
Post by DanTreace » Wed Sep 16, 2020 4:25 pm
Daniel
Ben's phone # is 77 ZERO-938-33 SEVEN 6
You'll receive a nice rebuild if you provide a decent core, with key helps too, write a note on what you want too in the box with it, also if you want ammeter too, provide that for also.
Just got this one returned, powder coated plate, rebuilt switch with new center tumbler, added my own ammeter. The letting is left unpainted, but easy to add over the powder coat would think. White enamel paint with a superfine bush, then wipe off excess around letter with simple paint thinner, (not lacquer thinner), as paint thinner won't typically harm the powdercoat.
SurveyKing
First Name: Daniel
Last Name: Snell
Post by SurveyKing » Wed Sep 16, 2020 6:08 pm
That is a very good professional job. I'll be calling Ben, Thanks
Jahn_Wright
First Name: Jahn
Last Name: Wright
Post by Jahn_Wright » Thu Sep 17, 2020 1:06 pm
A fine tip white paint marker from the craft store works great for the letters. Since they are stamped into the metal, you don't even have to be an artist to do a great job.
Jahn
1925 Coupe--owned by my Grandfather
SurveyKing
First Name: Daniel
Last Name: Snell
Post by SurveyKing » Thu Sep 17, 2020 2:22 pm
Thank you for that suggetion on painting the letters white Jahn will give it a try.
